Clear over OEM paint?
Old Nov 3, 2010 | 10:13 PM
asianflava's Avatar
Default Clear over OEM paint?
I bought a 91 CRX with great paint (for now). My experience with Honda paint of this era is that they aren't nearly as durable as a modern base/clear. Is it possible to clear over the OEM paint? Or will it require an entire respray.
Old Nov 4, 2010 | 12:29 PM
EJ1civic coupe's Avatar
Default Re: Clear over OEM paint?
itd be pointless..jest redo the whole thing..prime..base..clear..
Old Nov 4, 2010 | 10:44 PM
gorillafart's Avatar
if you're doing it the same color. u only need to scuff, base then clear.
Old Nov 5, 2010 | 03:21 PM
DC2.2_GSR's Avatar
No need to prime unless you're covering body work and are going to block sand it smooth. Also, no need to use sealer unless you're covering primer or mismatched colors.
To re-clear a whole car is to do an 'entire respray'. You're not saving any time or much effort by just re-clearing it. There are no steps that are different or any more/less work you'll need to do in order to put color on. Like gorillafart said, just respray both color and clear. It's a simple overall paint job.
tweensquirt
Paint and Body
Mar 19, 2012 06:20 PM
crxsir23
Paint and Body
Feb 24, 2010 06:12 PM
chinkyx90
Paint and Body
Apr 2, 2009 01:39 PM
Bulli Kid
Paint and Body
Aug 22, 2008 05:58 PM
REDTOPAlchemy
Dec 10, 2004 02:05 PM
