mixed opinions..what filler should I use?
OMG it'Z McFLY!
currently shaving my engine bay. every hole and seam has been welded and ground down. should I skim it with evercoat rage extreme or evercoat metal glaze. should it be applied to bare metal? thanks in advance.
u can go to metal, use the Rage, then epoxy and paint...
or you can epoxy it, then use the Rage, then paint
metal glaze i would not use. doesnt have the thickness to shave an engine back.
OMG it'Z McFLY!
wordd. the only reason i said metal glaze is because i welded and ground everything down and there isnt that much to "skim" over. but i guess ill go with the rage to be safe..
in the paint world, epoxy is a paint that refers to the first coat of that covers the bare metal, which aids in adhesion, and corrosion protection. its the best product that attempts to mimic factory E-coats from car manufactures.
