4000 RPM Max?
Old Nov 3, 2010 | 12:57 PM
cloud17's Avatar
Default 4000 RPM Max?
Hi I just want to ask why is that my 89 Civic LX wont go past 4000 RPM even if I push the pedal at full throttle on highway?
I think when it was on idle and I try to rev it up it goes past 4000rpm, but when I drive and hit the throttle full down, it wont go past 4000 RPM...why?
Old Nov 4, 2010 | 12:26 PM
Chiovnidca's Avatar
Default Re: 4000 RPM Max?
Is the engine in proper tune? The correct spark plugs? Ignition timing? Cam timing? Valve adjustment? Is the air filter clogged up? Does the fuel pressure drop off at as you rev it?
Old Nov 4, 2010 | 12:36 PM
wtf_is_jdm's Avatar
Did you do a recent T-belt job on it? Reason why I ask Is because when I did my last swap, the d-bag that I let set the timing basically 180'd my crank. I was curious why after 3 grand it had no ***** behind it and by the time I figured it out.... well boom.
ShawnbobHatch
Dec 30, 2008 12:00 PM
elcamino4x4guy
Feb 10, 2008 07:12 PM
freakasis
Feb 24, 2007 01:27 PM
fscot
Oct 5, 2005 03:29 AM
toooslow
Sep 29, 2005 07:11 AM
