FS/FT: 1999 Hona Civic EX B18b1 Swap, BBS wheels, D2 coilovers
1999 honda civic ex had this car for a little while now just wanting something different im mainly looking to sell it or trade it for a EP3 with cash on my end but heres the run down on the car
Motor: B18b1 110k miles on it, venom fuel rail, AEM adjustable fuel pressure regulator, gsr transmission, stage 3 clutch
Wheel: 15x6 38 offset BBS rz wheels..i painted the wheels myself they are purple have 2 coats of primer, 3 coats base, and 3 coats of clear i work at a body shop and thats where they were sprayed at
Suspension: 36 way fully adjustable D2 full coilovers, rides amazing, skunk2 front camber kit, ebay rear camber kit, D2 purple rear lower control arms
Interior: all stock no rips very clean carpet has some spots in it from being my DD but would prob come out with a good cleaning
Body: 174k miles i think, clean title, no major dents just some dings on it
BADS: ok since i put the swap in i messed up the dizzy so right now the car is in limp mode still runs and drives fine just wont rev past 3500 i know it my fault because when the motor was pulled it ran great its the crank sensor inside of the dizzy the only check engine light im throwing is number 4 and thats whats causing limp mode i have another dizzy with a good crank sensor in it but have not got around to changing them out yet because im always busy with school and work but i am trying to get this issue fixed ASAP since im trying to sale it...the speedo is not working it worked when the single cam was in it but after i swapped it it stopped working i know the VSS is good so im not sure what the issue is i havent looked into it very much...also i ordered a set of mounts and they sent me single cam mounts so im in the process of trying to get that situation worked out the driver side mount is off of the single cam so its just rigged up but its been working fine just waiting to hear back from the company that i ordered the mounts from so i can get the riight ones or a refund....car has ebay headlights, ebay tailights, and a ebay grille
I will sell the car cheaper if somebody wants to buy it how it sits those are really the only issues with the car, its a great little car when cleaned up looks pretty nice wheels set ot off and its not just another lowered civic its actually done right if anybody knows D2 suspension they know it isnt cheap car rides good to be sitting as low as it is
Also i will sell the car without the wheels for some less but you got to bring your own wheels
patric8332
Nov 6, 2010 09:58 PM
