Vibration when pushing on the gas petal?
Old Nov 3, 2010 | 02:19 AM
quickster's Avatar
Default Vibration when pushing on the gas petal?
Its more profound when I am going faster. I feel it more in the gas pedal than in the steering wheel at lower speeds. I can feel it in the steering wheel when traveling over 55 mph. It stops vibrating when I let off of the gas. I can be going 80 mph and no vibration, I push on the gas I feel it again, the harder I push the gas, the more vibration. Besides, getting my tires balanced, where should I start? I was thinking about starting on the wheel bearing and the ball joints to see if anything needs replacement.
Old Nov 3, 2010 | 06:02 PM
BetAda0064's Avatar
Default Re: Vibration when pushing on the gas petal?
Check your engine and transmission mounts.
Old Nov 3, 2010 | 07:39 PM
bassmek2's Avatar
are you sure it snot a missfire underload? if its automatic put it in drive, hold the brake and push on the gas pedal part throttle not for long just to see if u feel miss/vibration...
Old Nov 5, 2010 | 08:05 AM
rx7_dude2003's Avatar
Check your Axles.... if u have no misfire.
Old Nov 5, 2010 | 08:19 AM
Targa250R's Avatar
be professional
It's not a wheel balance issue if it only vibrates upon acceleration. Bad ball joints won't cause a vibration.
It's very likely that one or both of your inner CV joints are bad.
Old Nov 5, 2010 | 03:03 PM
quickster's Avatar
I was thinking that maybe it was that too. I just got my tires rotated and balanced today and its still doing it, so that definitely wasnt it.
It tends to vibrate harder when going uphill or when its lugging a bit(accelerating from lower rpms~2000-3000.) and starts clearing up once I get it above 3500 rpms.
I'll start with pulling the cv boot back and checking for damage. You are probably right. I hope its that, because thats something I could fix myself, and won't be too expensive.
***to the guy that asked if i drove an automatic. I actually drive a manual stick and clutch.
From the way its driving, part of me thinks this is a transmission or driveaxle issue since it only vibrates on acceleration. Gotta start with the easier stuff first though.
Old Nov 5, 2010 | 09:15 PM
Targa250R's Avatar
be professional
If you replace the axle(s), don't buy cheap remans from a chain parts store or else you'll continue to have problems.
Make sure to get a 100% new axle such as Mevotech, EMPI, FEQ, etc.
Old Nov 8, 2010 | 12:31 AM
quickster's Avatar
will do, its not knocking yet, so wouldnt i just replace the boot instead of the whole axle? i honestly dont know how it all looks down there at this point.
Old Nov 8, 2010 | 03:16 AM
Targa250R's Avatar
be professional
The boot may or may not be split open. Even if it isn't, the CV joint is already bad if it's causing a vibration upon acceleration, so you need to replace the whole axle.
An inner CV won't make clicking noises if it's bad; only the outer CV joints will. The inner joint and the outer joint are not of the same type.
Old Nov 8, 2010 | 09:35 PM
quickster's Avatar
thanks for clarifying on the difference for troubleshooting, I know what you are talking about since I've looked at diagrams on the axle itself.
Old Nov 11, 2010 | 06:29 AM
2001B18C1GS-R's Avatar
axles for sure had happen to me in my integra bought some **** cheap remans axles and did the same thing put 2 brand news in and no problem
NickH93
12
Oct 26, 2014 03:39 PM
Mishako129
Sep 29, 2012 06:45 PM
DumaDA
Dec 17, 2009 02:34 PM
202B
Acura TSX
Apr 14, 2008 11:38 AM
Tizight
Dec 6, 2007 08:16 AM
