civic ef rev problem
Old Nov 2, 2010 | 04:32 PM
civicef990's Avatar
Icon2 civic ef rev problem
hey need some help.. i have a 90 civic si hatch with a b16 obd1 jumper harness with a p72 ecu..i already changed the injectors and fuel pump because i had a code for fuel supply system...if i hit the gas hard it feels like it chokes, but if im easy on the gas it revs up just fine...any ideas on wat it could b??
Old Nov 2, 2010 | 07:52 PM
jdm ef8 89's Avatar
Default Re: civic ef rev problem
Well if you know you have a fuel system problem and you've already replaced the (right) injectors and fuel pump. It could be a bad main relay(not turning fuel pump on/keeping it on), bad fuel pressure at fuel filter (bad washers/would be leaking fuel), and just see if your geting fuel to the rail/injectors and find out where in the lines your problem is at.
Old Nov 2, 2010 | 08:14 PM
civicef990's Avatar
yeah I replaced injectors, fuel pump with a walbro 255 n i got like 49psi at the filter.....no leaks no more codes, the car starts n runs fine as long as I dont push the gas too hard soo im not sure wat it could be
thanks for ur time
Old Nov 3, 2010 | 12:23 AM
Grey_Matter's Avatar
hows your timing?
sounds like you could have it retarded a bit too much
Old Nov 3, 2010 | 12:31 AM
dohc4life's Avatar
its your 02 sensor i promise either get it chipped for no 02 or replace it
Old Nov 3, 2010 | 12:32 AM
dohc4life's Avatar
fuel supply code just means your cars running to rich or too lean unplug your 02 sensor and see what happens you should feel normal until your cars warmed up and then youll feel how you described i had the same problem
Old Nov 4, 2010 | 09:54 AM
civicef990's Avatar
ok it sounds like it could be it...but i dont have anymore codes tho...bt i will try that when i gt home from work and ill let ya know how it goes after i try that...
thanks everyone for ur time
Old Nov 4, 2010 | 05:43 PM
LSVTECEF91's Avatar
yepp get a chipped p28 i was having the same problem too but mine was when vtec ingage
Old Nov 6, 2010 | 09:32 PM
civicef990's Avatar
hey sorry it took me long to reply,bt i tryd wat ya'll said about the o2 n nothing it still the same....is weird bcuz even with a chipped p28 still doing the same....idk wat to do now thanks everyone for the time
Old Nov 6, 2010 | 09:37 PM
tyked15's Avatar
dizzy? my buddys car did the same thing think it was his coil? not so sure but i know it was something with the dizzy
Old Nov 10, 2010 | 11:04 PM
dohc4life's Avatar
if its chipped turn the 02 off
Z0831xiz
Jun 17, 2013 05:14 AM
TurboedGSR
Aug 6, 2008 12:57 PM
datnigabluberry
Mar 29, 2007 05:53 AM
Backk InTheDA
Feb 24, 2005 03:52 PM
