interchangeable injectors for mpfi crx
Old Nov 2, 2010 | 04:29 PM
The Hooligan's Avatar
From: spinning DnB till your head explodes,jersey/philly
Default interchangeable injectors for mpfi crx
putting an obd1 d15b in my mpfi crx and completely forgot i need obdo injectors.
im headed to the junkyard tomm and i know for sure theres no 88-91 mpfi crx/civics there.
i do know theres an 87-89 integra and 90-91 integra there, im pretty sure these work, just need confirmation. is there any other hondas that are straight plug & play with 88-91 mpfi crx/civics ? thanks in advance.
btw, forgive my ignorance...
Old Nov 2, 2010 | 04:51 PM
black0hatch's Avatar
Default Re: interchangeable injectors for mpfi crx
b and d series are the same. you can use obd1 injectors too. but youll have to delete the resistor box just solder all five wires together and the obd0 plugs arent exactly the same as the obd1 injectors you can either shove them on thats what i do or repin the obd1 style plugs on.
Old Nov 2, 2010 | 08:56 PM
anyone else?
do the 87-89 and 90-91 integra injectors clip into the stock plugs ?
Old Nov 3, 2010 | 06:24 AM
im considering switching too obd1 in the future, so for the time being while its still obdo i can run the obd1 injectors, ditch the resistor box, and wire the 5 wires together?
Old Nov 3, 2010 | 06:35 AM
b16eg684's Avatar
obd1 injectors will fit not obd2
Old Nov 3, 2010 | 06:37 AM
b16eg684's Avatar
and yes 90-91 will fit
sixstroke
Aug 12, 2014 02:42 AM
e jay one
Sep 10, 2005 09:15 AM
MidoriEK4
Apr 27, 2003 09:49 PM
Mase
Sep 30, 2002 12:14 AM
