TOOO hot for TOOO long
Old Nov 2, 2010 | 02:25 PM
BoltSOCpower's Avatar
Default TOOO hot for TOOO long
ok on my prelude 1993 with f22a1
Ebay header 2.5 collector
2.5 mandrel bent exhaust no cat
Cold air intake AEM
Problem: Car runs way to hot in stop and go traffic
3/4 on my dash gauge.
solution: replaced water pump/timing belt
replaced radiator. and hoses.
bought new cooling fans.
put a heat wrap around exhaust
replaced therm
new after market gauge for temp.
200-220 seems too hot for my liking
still runs at 1/2 on open road 3/4 in city driving
anyone got some ideas? i've spent about 250$ and have had no luck
my buddy's prelude doesn't ever run past 1/2 on his gauge and he has similar mods exhaust and intake.
whats causing this? is it too hot? i searched for temp.'s cam up with nothing.
not throwing a check engine light!
Old Nov 2, 2010 | 02:35 PM
godslayer's Avatar
Default Re: TOOO hot for TOOO long
Replace OEM heat shield?
Maybe that cheap (inexpensive), thin gauge, ebay header creates a ton of heat under the hood.
Old Nov 2, 2010 | 02:38 PM
OEM heat shield...
thin metal sheet bolted around stock manifold?
Old Nov 2, 2010 | 03:23 PM
TheJGB3's Avatar
Operating temperature for most engines is ~195*F-220*F
Old Nov 2, 2010 | 03:56 PM
so 220-230 is just it being in stop and go traffic nothing to worry about?
Old Nov 2, 2010 | 04:31 PM
ByrdB20's Avatar
Have you checked or changed the thermostat?
Old Nov 2, 2010 | 04:35 PM
godslayer's Avatar
Originally Posted by BoltSOCpower
OEM heat shield...
Yeah, if it fits. Air is a better insulator than whatever you might be able to wrap around it the tubes. Is the header ceramic coated? Likely not but I thought I'd ask.
Old Nov 2, 2010 | 07:42 PM
jordan_rael_420's Avatar
do that if u havent. check ur fans make sure there coming on. pressure check ur radiator cap
Old Nov 3, 2010 | 05:09 AM
ilikehonda's Avatar
are you sure the sending unit is functioning properly? does the temp go down almost immediately after you start moving in stop and go traffic?
Weak!EG
Feb 16, 2010 05:41 PM
Arthas
Engine Management and Tuning
Feb 8, 2010 09:52 AM
acura9
Nov 26, 2006 08:44 PM
AnthonyG2003
Nov 27, 2005 03:56 PM
canadiancoch
19
Jan 13, 2004 11:41 PM
