november fs sticky
Old Nov 2, 2010 | 11:47 AM
boostedcivicsir's Avatar
Mr. Badwrench
Default november fs sticky
Please read the rules for the new thread. At the end of each month this thread will be unstickied, and a new thread created in this one's place. If you haven't sold your parts, you may post them in the new month's thread. DO NOT BUMP THE OLD THREAD
1) This is for RaceCar parts ONLY. No body panels, fenders etc allowed, unless it is a full race front end. ABSOLUTELY NO useless OEM parts!
2) Do NOT repost your thread over and over hoping to get it on a new page. If your parts sell please remove them from your post. If you sell everything off of your list of parts, report your post to moderator by clicking on the just under your user name and we will delete it.
3)You are ONLY allowed ONE post in this thread. If you are found to have more than 1 post, in the FS sticky all of your posts in the sticky will be deleted, and you will be given an infraction. With enough infractions you will be banned
4) NO WTB ADS!
5) NO COMMERCIAL POSTS AT ALL THIS MEANS, IF YOU OWN A SHOP DO NOT POST BRAND NEW PARTS IN HERE
6) Please provide all pertinent information, including price, and try to return pm's.
We will delete any BS we feel does not belong in here
Please try and limit the size and # of pictures you post. using thumbnails would be fantastic.
From this point on, 1-1-2010, any edit mods have to make to these threads, will result in sanctions. if it persists, the stickies will disappear for good. THIS WILL BE ADHERED TO. No more warnings.
Mr. Badwrench
Default Re: november fs sticky
ipg v1 race cams
exedy twin used for 4 years. 450.00 still in the car be out soon.
bogart rt5's 5x114.3 (itr wheels) with 24.5 x 3.6 x 15 m and h's 500.00
msd 75611 programmable rev limiter for analog boxes 150.00
Old Nov 2, 2010 | 12:00 PM
onefstek's Avatar
K24a4 block with pistons/rods
Bored and honed to 88mm
Decked just enought to clean it up
K24a4 timing side cover
K24a4 timing chain
K24a4 stock crank
New Wiseco 88mm 14.1:1 cr pistons
New Eagle H beam rods
Price: $2100 Not assemlled OBO
Garrett GT4088R
Price: $1250 OBO
Used but in great condition.
DSS 5.9 Axle Kit for a EK with EKK1 mounts
Price: $1450 OBO
Old Nov 2, 2010 | 12:08 PM
rota92
Guest
Posts: n/a
For sale is my 2007 Chevy Silverado 3500. This truck has been great to me but I’m getting out of racing so I no longer need it or my trailer. The truck is loaded with the LT1 package, currently has brand new Michelin LTX M/S 2 tires on the stock wheels, and a full MBRP turbo back exhaust. I have the stock one in great condition I will include with the sale, or install it ahead of time.
This is the newest truck you can get pre-new emissions hardware. The truck towed awesome as expected. I only had a trailer behind it for maybe 7-8k miles. The rest were actually for commuting since I used it as a daily driver for about 2 years. It currently has 61,500 miles. It’s always been serviced at the proper intervals, the truck keeps track and I’m usually a little ahead of the curve.
It has the OEM towing package installed, as well as a fifth wheel hitch that can also be included. When I get back into racing I am not going to bother with anything but a fifth wheel trailer, they tow absolutely amazing.
I’ve installed 2500 HD taillights which look great on the white truck, the OEM ones look cheaper with the plastic bezel. I have those still if you’d like them instead. I’ve also installed a front lower bumper lip from a lower model, strictly for looks. I recently had the truck detailed and it looks its best.
61,500 miles
Duramax Diesel with Allison 6 speed automatic trans
Tow/haul mode with manual selection mode
LT1 package – Leather seats, front electric, front heated, Bose sound system, DVD/TV
Stock wheels painted black
Michelin 265/85-16 LTX M/S 2 tires with 2k miles on them
Fred’s 2” wheel spacers
Taillights off 2500 HD
Front lip off 1500 series trucks
Silverstar bulbs in all front lights
MBRP 4” turbo back exhaust
Diablosport programmer – used to adjust speedo with the larger tires
Towing package
5th wheel hitch available
I’m also selling my 1997 Wells Cargo 40’ trailer. It has new tires and brakes on it.
I’m sure there will be questions, feel free to email me and I will get back right away!
Asking $34,000
1997 Wells Cargo 40' gooseneck trailer - 8500
New tires/brakes, in floor winch/storage area, 8' of e-track, diamond plate floors, outlets all over and very well lit. Pleast PM me for more pics
https://honda-tech.com/forums/showthread.php?t=2183089
That’s the build thread with more specific pictures, if you need any others let me know and I will send them over.
List of parts:
Chassis: Will not part doors/hatch, those are built around the chassis and need to stay that way for now.
· 25.5 spec (not yet cert’d, built by NRG to pass cert) 1992 Honda Civic Si
· Strange Rear shock/hub/brake combo. 90lb springs. Double adjustable.
· Rob Moore/Nitro Driveline – Hubs/brakes, axles, halfshaft, spool (Will part)
· JAZ 3 gallon fuel cell
· Kinsler mechanical fuel pump and filter
· Charge pipe with 2 downstream injector port
· CNC pedal assemblies - Sold but still set up for these
· Kirkey pro-drag seat (mounted to fit into car)
· Mezeire WP366 16v water pump (Will Part)
· Franks fiberglass front end
· Franks fiberglass doors/rear hatch
· Parachute mount
· Carbon fiber sunroof plug – not installed since fabrication is not complete
· Weld Magnum skinnies w/22” MH tires
· Weld Magnum fronts 15 x 10. 4” backspace, 5 x 4 ¾ bolt pattern. (Chevy) Used 28 x 10.5” tires on them (Will part, unlikely others have the bolt pattern though)
Electronics:
· M&W Pro-Drag Ignition box - 950
· AEM Serial gauge - Custom fuel pressure setup to read higher pressure (above 200 psi) – 250
· (2) AEM Water temp gauge – 175
· AEM EPM - SOLD
· AEM UEGO sensor (external) (Reads low enough for methanol) – 160
· ARC electronics Switch panel w/firewall mounted panel - 350
· 128 pin cannon plug w/1 backshell and pins - 250
Universal Parts:
· Bullseye Power S374R w/1.25 exhaust housing (Polished cover) – 1600
· XS power 16v battery – 225 (may be surcharge for shipping due to weight)
· Safecraft Fire suppression system – (Need to check date and info on if it’s good, but still works and I have all pieces)
Old Nov 2, 2010 | 12:14 PM
h22 civic's Avatar
silver pro comp 2.1/16 water temp gauge 100-250 temp=30 bux
silver pro comp 2 1/16 0-100 oil psi gauge 40 bux
aem wide band gauge with new sensor 175 bux
silver sport comp monster tach 10,000 with adjustable rpm setting and external shift light=175 bux
phantom 2 1/16 0-100 psi mechanical fuel gauge 30 bux
phantom 2 1/16 30psi boost gauge 40 bux
96-00 civic 2 gauge cluster bezel 30 bux
autometer low oil psi pencil warning light with 15 psi sensor=40 bux
2 gauge pillar mount for 2 1/16 gauges fits 96- civic/integra =25 bux
00 civic si cluster 175 bux
aem twin fire and aem pencil coils make offer
aem 30-1020 ems for obd2 already setup for coil on plug with a few h22 turbo programs in it $600
ferrea roller rocker setup for h22 with h22 all motor roller cams mint like new $1500 or just sell cams seperate( pm for cam card)
2-24.5x8.5x15 m&h slicks lots of meat left work good 200 bux
2- 15"x7" rota sub zeros flat black look new 5x114.3 very light weels 200bux
2- 205 50 15 mickey thompson et drag radials basically brand new used for 1 day of photo shooting (not 1 burn out on them) sold
5x114.3 bogarts slicks and skinnys plenty meat left sell all for $1000
full msd setup will sell cheap blaster2 coil 6al msd wires etc
fullrace_t3 t67ho turbo 82 back/70 front housing p trim wheel no probs at all make offer___
zex dry nitrous kit mint 250 bux
misc stock h22 stuff pm with needs_________
__________________
Old Nov 2, 2010 | 12:30 PM
xsi-t's Avatar
Things have come up so i must sell asap.
Bullseye power s366
$500 obo
matching 4inch Downpipe
$150
Ramhorn T4 manifold
$550 obo
willing to sell together for 1,000.
This setup made 650 on 28psi falling to 25psi.
Old Nov 2, 2010 | 12:33 PM
d112crzy's Avatar
Default H22 pistons
sold
Old Nov 2, 2010 | 12:41 PM
Garage 808 Hatch's Avatar
S372r exhaust housings
.90 divided coated black
1.10 divided not coated
will trade 1 or both for a 1.25 divided housing
aeromotive a-1000 pump $150
MSD digital 6 plus with (ss coil used for 3 passes) $300
Old Nov 2, 2010 | 02:34 PM
zakura R's Avatar
Call or text 978-944-3095
60mm turbo smart waist gate $380ship
H22 use 9:1 comp 87mm cp piston $125 ship
H2b t4 forward facing turbo manifold set up for a 60mm waist gate $600 ship
Garett intercooler core size 18x12x4.5 $350 ship
Map censor 7 bar like new !!!!!!!!!!SOLD!!!!!!!!
H22 coil and distributor set up $200 ship
Automotive fuel regulator big port !!!!!!!SOLD!!!!!
H22 H-bem eagle rods 8 pass on them $250 ship
H22 skunk2 tuner 2 cam!!!!!!!!!!!SOLD!!!!!!!!!!!
Automotive pro series fuel pump 8 dyno pas on them $400 ship
Msd 6AL $100 ship
B-series avid solid motor mount $300 ship
B-series edelbrock intake manifold $280 ship
B-series msd coil with distributor $200 ship
Gsr tranny liberty face plate with mfactory 1ro gear liberty cuff and weld it diff ,and up grade mechanism tranny has only 3 pass and 9 dyno pull !!!!!!!!!!SOLD!!!!!!!!!
LS golden eagle sleeve block with oring , Manley rods and up grade wrist pin ,cp piston 9:1 comp ,z10 main girdle with arp bolt,moroso oil pan!!!!!!!!!!SOLD!!!!!!!!!!!
1993 eg coupe with 8 point roll cage , shave engine black engine bay ,skunk2 front control arm , and real camber kit ,3 piace jojo Calos front ,lexan window all around front and back and quater $ 2,000 pick up only
Old Nov 2, 2010 | 02:47 PM
RACEPAK's Avatar
haltech e8 with subaru imprezza gt adapter $950
haltech e6 series e6x e6k e6s atapter harness to HONDA/ACURA OBD1
new venom B cam gears 110+ shipping
hasport mount 80+shipping
new fuelab fuel filter 100 + shipping
new greddy type r no diaphragm 70+shipping
apexi twin chamber new just painted, 90+shipping
Old Nov 2, 2010 | 03:12 PM
BADGUYNY's Avatar
All 3 $700
Inline pro T3 log mani
3" downpipe(made by Suppy of LM24)
Dumptube (made by Suppy of LM24)
Will no part Must be purchase together
Tial 38 wastegate with .5 bar spring $150
PWR bar & plate intercooler rated for 500hp $275
Old Nov 2, 2010 | 03:16 PM
91turbove's Avatar
NHRA approved catch pans, designed to work with tracktion bars and 4"downpipe
make a 'realistic' reasonable offer
BNIB full-race t3/67 ho, p trim, stg 5 exhaust wheel, 70ar compressor housing, 1600* coated 82ar exhaust housing. had a 3" vband welded on, t3 footprint
$950shipped
tial 50mm BOV $155 shipped
walbro 255lph pumps(x3)
Old Nov 2, 2010 | 03:25 PM
91redteg's Avatar
I have a set of used precision 1000cc injectors they were on my turbo k series making 500, selling these because i got 1600's. looking to get 200 shipped these are part number 1711374-95
Old Nov 2, 2010 | 03:35 PM
SPOOLINmatt's Avatar
ARP Head Studs
GSR B18C1....Also works with LS VTEC setups
Torqued a few times, just upgraded to stronger studs for the hell of it...these still hold just fine.
75$ shipped.
Catch can setup for sale...Bolts to a 96-00 civic driver side wheel well. It holds about a gallon and is baffled with 2 filters. It has 3 -8 ports on top that are where the AC dryer cylinder would usually be. I have 2 of the ports connected to the valve cover. Im selling the custom can with valve cover and lines to connect it.
$350.00 ......
Pic doesn't show the filters in place because this was during fabrication...but there are 2 side by side, the same size as the "standard" catch can setups out there. It has a drain plug at the bottom.
I also have this Inter cooler, It has a Tial BOV flange on the driver side but who knows what you'll have to modify with the tanks to make it work for you.
Spearco 10"x24"x4.75"
$175$
Old Nov 2, 2010 | 03:42 PM
narfdanarf's Avatar
Exospeed "lenso" VPD flat black 13" drag wheels with M/T 24.5x9x13 slicks....approximately 15 passes on combo. SOLD
S372 1.00 A/R turbine housing - Best Offer
Jim Stewart Racing Engines ported b16 head...bare head with matching cam caps and Ferrea guides, will need valve seals installed. Designed for .5mm o/s intake and exhaust valves. - $1000 shipped will throw in used ferrea 6000 series valves for extra $150
2 black Fuelab 75 micron fuel filters with -8 connections on each side - Best Offer
Hasport driver side mount for Bseries into EK $75 shipped OBO
Old Nov 2, 2010 | 03:55 PM
tepid1's Avatar
Prologger wideband/boost controller/rpm activated switch.
Comes with a brand new Bosch o2 sensor. Unit is mint and works perfect. Included is everything as if it was brand new.
$400 shipped
Meziere water pump kit for Honda/Acura 22 tooth kit.
Comes with everything as if it was new. I went with a radiator mount water pump instead of this. Never used it.
$330 shipped
Quantum start/bump push buttons.
Ordered too many by accident. I have 2 left.
$10 shipped (each)
Z10 breather block fittings 1/2 inch barb.
They sell for $25 each and I have 2.
$40 shipped for both
SPA Techniques Gauges.
Boost/EGT
Oil pressure/Fuel pressure
The setups are complete from gauge to sensor.
$300 shipped for both and I'll even throw in the DC2 Autometer cluster.
PM me with questions. More pics to follow.
Old Nov 2, 2010 | 04:36 PM
jdmintegraxsi's Avatar
AEM EMS 30-1070U
This unit was plugged in for start up but was never ran in the car. Wideband was never used. Everything is still in the box ready to be shipped out.
$1250 Shipped
Old Nov 2, 2010 | 04:37 PM
Will_H's Avatar
Up for sale is a MINT Bullseye power S372 turbo! It was just sent out to Bullseye for a checkup/rebuild by "Wild Bill" at Bullseye! Fresh heat coating done by IPGcoating.com. 4" v-band exhaust housing.
Turbo has 5 dyno pulls on it since rebuild. Has not been run since the coating! No shaft play,bent/chipped fins. Mint! $850.00 Turbo was purchased new from Tony @T1 racedevelopment
I'm down grading to run at 67mm turbo to run True Street!
M&H street/strip DOT slicks,used these things get super sticky when warmed up and hook amazingly. 235/60/15 on 15" rims 4x100 ready to go! $200
Stinger SP800 battery great for cars with big systems or just cranking amps. $75 works great!
MSD cap and rotor b-series gsr new still sealed in original package part #82933 $60
Old Nov 2, 2010 | 07:24 PM
B18C1CYA's Avatar
OBD1 P28 ecu with the new version neptune rtp , comes with paper work and cables , $450 shipped
Old Nov 3, 2010 | 03:54 AM
T76U13ALT's Avatar
I have a set of used T1 brackets for the long shifter. I'm asking $125 shipped in the USA.
Old Nov 3, 2010 | 05:54 AM
tuhboek's Avatar
1. Bullseye Power S366 T4 Turbo
Honda/Acura T4 TURBO S366 - $1000 OBO/ Trade for 72mm turbo
Bullseye S366 Turbo (Capable of upwards of 800hp) BIG POWER
.91AR
T4 flange
Vband exhaust
This turbo has been installed on my car and only started up to test for oil leaks...Other than that it is brand new....it has never seen any boost nor Dyno time. Wanting to
sale so I can get a S372 or a precision turbo of compatible size.
2. MSD 6AL ignition box with HVC coil-$150 OBO
3. have a D-series bare block and Transmission for spare parts. –Make offer
Prices do not include paypal fees or shipping fees, it is all negotiable though.
More pics upon request
Call/text for fast response: 620 262 7796 or send a PM
Old Nov 3, 2010 | 06:11 AM
dester223's Avatar
I have a total of (4) 25x4.5x15 ET fronts available.
Bought them and never used it.
Jegs/summit is ~ 145-146 + shipping
I am asking 120 each OR BEST OFFER
Old Nov 3, 2010 | 06:18 AM
JdMhEaD's Avatar
B16 Head
dual valve springs and titanium retainers (hold 9700 fine)
stock valves
no warping
$450
GSR transmission - No LSD, New 2nd gear slider, new 2nd gear Transmission is smooth as butter.
$500 OBO
Innovative 95a mounts for eg/dc with 3 bolt driverside mount.
red inserts, polished exterior
$250 obo
- Garret T3/T67 been used, makes 600hp at 30psi with ITR cams on a 2.0L Compresser fins are chipped on outer edge - $500FIRM!!!
- Peakboost charge pipe kit with all couplers and clamps - $200
- Tial 50mm BOV Silver - $150 OBO!
- AEM injector Driver $150
text me @ 205-401-1433
Old Nov 3, 2010 | 07:58 AM
PT66Y922Rx83's Avatar
Default MoTec M880 w/ harness and extras
Price
$6500 obo
Contact information
(713) 772-7223
Is the item new or used
Used
Product description
Motec M880 Engine Management
http://www.motec.com.au/m880/m880overview/
Unlocked Options:
Single Channel Wideband
Advanced Functions
Advanced Tuning
Additional Logging
Standard Options:
• Traction Control and Launch Control (2, 3 or 4 wheel)
• Gear Change Ignition Cut (flat shifts)
• Overrun Boost Enhancement ‡ (anti-lag)
Included Optional Parts:
Unterminated Milspec Harness w/ Autosport Connector ($1500)
Motec UTC USB to CAN adapter (BNIB) ($350)
The M880 is MoTeC’s top of the line ECU. Developed for motorsport professionals, it takes the M800 engineering one step further with an Autosport connector, Advanced Functions‡ as standard and an optional 4 MB logging memory.
This powerful ECU suits the same broad scope of applications as the M800, including modern engines with up to 12 cylinders and twin, triple or quad rotor applications.
It offers maximum sophistication to control the latest automotive advances, such as continuously variable camshaft timing and drive by wire throttle, while maintaining the flexibility to suit a range of users.
* Advanced Functions include: Traction Control, Launch Control, Gear Change Ignition Cut (flat shifts) and Overrun Boost Enhancement (anti-Lag).
BASIC SPECIFICATIONS
Outputs
• 8 x Injector outputs—high or low ohm ‡
• 6 x Ignition outputs ‡
• 8 x Auxiliary outputs—for functions such as camshaft control, drive by wire throttle, boost control, nitrous injection, idle speed stepper motor and many more
‡ Optional injector / ignition configurations:
(requires 10/12 Cylinder Sequential upgrade)
10 high ohm injector outputs and 4 ignition outputs
12 high ohm injector outputs and 2 ignition outputs
Inputs
• 8 x Analogue voltage inputs—fully configurable including custom calibrations
• 6 x Analogue temperature inputs—fully configurable including custom calibrations
• 2 x Wideband Lambda inputs—for Lambda measurement and control
• 4 x Digital/speed inputs—for wheel speeds and function activation
Communications
• 1 x CAN
• 1 x RS232
Physical
• Case size 147 x 105 x 40 mm
• Weight 525 gram
• 1 x 66 pin and 1 x 26 pin waterproof connector with gold plated contacts
Old Nov 3, 2010 | 09:13 AM
redboost10's Avatar
Motec M4 with Advanced Logging and Tuning
M&W Pro-12 CDI Ignition Box with 4 Honda CBR coils
Prologger Wideband and Boost Controller Kit
AEM 5bar Map Sensor
T1 cam trigger sensor
Mil-Spec Tefzel wire/Raychem DR-25 heat shrink/Deutsch connector harness
4 relays for radiator fans, vtec, fuel pump, ignition
VSS integrated into it with output for the stock cluster
Alternator line integrated into the harness
Injector Dynamics 2200cc injectors
Pm me offers
