red line'n problem..help!
Old Nov 2, 2010 | 12:23 AM
krazy newbie's Avatar
Default red line'n problem..help!
my buddie has an eg with a ls-vtec swap is red line'n at 6k..we tried everything from swapping out the ecu,distributor,engine harness,he even swapped out the head..no CEL's..we rev'd it while the car is not moving and moving and still wont go pasted 6k..could it be in limp mode? how can i tell if its in limp mode? how can we get it out of limp mode if it is in limp mode? any help would be appreciated...thx!
Old Nov 2, 2010 | 01:01 AM
siregcivic's Avatar
Default Re: red line'n problem..help!
mmm are you sure the tachometer is not off??? go drive it see were it hits vtec at, i had a friend that had a sohc vtec in a eh2 and i tuned his car set vtec at 4500 and rev limit at 7500 and his stock tach would only rev to 6400 no matter what, but it hit vtec at like 3k lmfao his **** was way off...
try changing out the cluster and see what happens...
does it sound like its only revving to 6k?
Old Nov 2, 2010 | 12:00 PM
the tach seems fine & vtec cracks at 4500..yeah it sounds like its only up to 6k..
Old Nov 2, 2010 | 12:09 PM
DDTECH's Avatar
stock ls bottem ends shouldn't rev higher then 7500rpms any ****en way.
Old Nov 2, 2010 | 01:13 PM
he would love to take it to at least 7k but no bueno..lol
Old Nov 3, 2010 | 12:46 PM
Old Nov 7, 2010 | 08:27 PM
ttt
Old Nov 7, 2010 | 08:31 PM
2k.civic.si's Avatar
what ecu are you using?
Old Nov 8, 2010 | 08:36 AM
92cxhatch169's Avatar
DOES IT HAVE A TUNE?
Old Nov 8, 2010 | 10:58 AM
RED_90TEG's Avatar
From: where i stunt SAND CANYON in Southern California
make sure u have the correct ecu
Old Nov 8, 2010 | 11:24 AM
Garage 808 Hatch's Avatar
wrong, just the heads shouldnt be revved past 7500
Old Nov 8, 2010 | 07:15 PM
ALL_MOTOR_FKR's Avatar
bump cause my buddy is having this same problem and also tried the same things you have and it is still doing it.
Old Nov 8, 2010 | 07:21 PM
raverx3m's Avatar
do you have aftermarket ignition like MSD ignition box? they have a rev limiter i belive(some of them)
maybe make a video. borrow a monster tach from someone and check to make sure your cluster is not off. where does it idle?
your chipped ECU also has a rev limiter feature(if its chipped)
Old Nov 8, 2010 | 07:55 PM
EHondaJDM's Avatar
No, he's right. Them rod-bolts suck ***
Old Nov 8, 2010 | 10:31 PM
currently using a stock p28 ecu..but we tried using a friends chipped p28 that went up to 8500 no problem on his car and still the same problem..no kind of msd on it except spark plug wires..and it idles around 800-1000
Old Nov 9, 2010 | 11:28 AM
fv8s's Avatar
nope your wrong, if you want to rev a stock LS bottom end North of mid 7's thats fine. just let us know how many days that lasts
Old Nov 9, 2010 | 11:32 AM
fv8s's Avatar
did you take a distributor from your friends car that was 100% working? that would be the first place I started. is this so called "EG" you have an EJ or an EH?
Old Nov 9, 2010 | 04:29 PM
yes..tried plenty of distributors from my friends car that are working fine on there car...no its not a ej or a eh its a eg 93 civic cx hatchback model
Old Nov 9, 2010 | 04:44 PM
jdmh22eg2's Avatar
LOL dumbass learn something about honda before u post plz IT IS a EH2 not a eg 99% of any "eg" in the us is a EH? not a eg
http://hondaswap.com/reference-mater...s-codes-31271/
Old Nov 10, 2010 | 11:59 AM
ooh smarty pants..thx for the lesson! and that still didnt help the problem! =/
Old Nov 10, 2010 | 07:41 PM
jdmh22eg2's Avatar
well if i had to add some help it is very unlikely but seen 2x's were a faulty VSS would limit the RPM of motor 1 threw a CEL 1 did not-- prob has something to do with the signal wire (not battery V) having to much resistance throwing off ur tach or ecu
Old Nov 10, 2010 | 09:59 PM
which one is the signal wire?? sorry ima newb pics would be helpful too..lol
Old Nov 11, 2010 | 05:14 AM
jdmh22eg2's Avatar
umm when i get to school i will post a pic
Old Nov 11, 2010 | 06:10 AM
jdmh22eg2's Avatar
ok i just looked at the wire diagram for the VSS and the out going signal wire is blu/wht and then turns into a orange wire when it comes out of connector C127(at the big connector by the brake master cylinder) so u will want to get a DMM(dig multi meter set on OHMS) and check the resistance from VSS plug and the C127 BEFORE it turns orange
meaning u want to check at the plug same color wire at both plugs and report back with ur OHMS reading
the wire may not be ur issue it may be the VSS top portion cause it is a electrical pulse piece so the top half of the VSS may just be bad
Old Nov 11, 2010 | 10:14 PM
ok ill check the ohms reading when i have time and ill report back..can i just replace the whole VSS and itll be good?
