MPFI Swap: It runs
Old Sep 20, 2002 | 08:16 PM
b16awarrior's Avatar
New User
Default MPFI Swap: It runs
It's finally over. After 4 days of hell, my dx finally has MPFI. And all I can say is very very nice. Just need to figure out this surging idle problem and all will be cool. Thanks to everyone who helped when I was going out of my mind.
Old Sep 20, 2002 | 09:01 PM
Mugen Dom's Avatar
Default Re: MPFI Swap: It runs (b16awarrior)
probably the eacv u should clean it out with some carb spray cleaner and blow it out with some copressed air
Old Sep 22, 2002 | 02:22 PM
New User
Default Re: MPFI Swap: It runs (JdMB16Ahatch)
It's fixed. Everything works perfectly. I'm loving this swap.
Old Sep 22, 2002 | 07:27 PM
Mugen Dom's Avatar
well tell everyone how u like it tell them how much better than the dpfi it is u know u want to do a testimonial
Old Sep 22, 2002 | 09:44 PM
johnzm's Avatar
Old Sep 23, 2002 | 04:32 PM
phoboyjimmy's Avatar
congrats. i did mine yesterday and all went well. my only problem is that my car is idling HIGH @ 2-3k RPM. i was told that it's the EACV. i'm also guessing that it's the throttle cable. i'm swapping both out tonight (hopefully) and we will see what happens.....
in terms of a review, it pulls SO MUCH MORE!!!! gotta love that extra power!
Old Sep 23, 2002 | 04:35 PM
EL Vap133's Avatar
Default Re: MPFI Swap: It runs (phoboyjimmy)
Finally Yimmy!
Old Sep 23, 2002 | 06:09 PM
New User
Default Re: MPFI Swap: It runs (Vap133)
Well waht can I say? I had almost given up on my car last friday when it refused to start. I kept thinking that I should have left it alone at first, that I was in over my head. But with the encoragement and support of my friends and family, I pressed on. After four unbelievebly long days, she turned over and roured to life. The sound she makes with my testpipe is is so smooth, not annoying like I thought it might be. Here's the stange thing the engine runs smoother, and before the swap it took her awhile to turn over, now she just turns on. My friends new RSX doesnt even do that! And the engine is so quiet at idle, you think the car was off. The only thing I need to do now is figure out how to lean her out she seems to be burning a little rich. This is all on a car with 187,000 miles on the stock motor and she's pulling hard! I recoomend this mod to everone who has a Dx. You'll love your car so much more. P.S. had my first race today against a 92 civic ex. We were about neck and neck, then he pulled on me at the very end. But then he had mods. I love it!!!!
Old Sep 23, 2002 | 06:14 PM
HatchBox's Avatar
Skoobie no more...
i want one for my civic...
Old Sep 23, 2002 | 06:18 PM
Jockobo's Avatar
Default Re: MPFI Swap: It runs (xxkenyon419xx)
good job...
Old Sep 23, 2002 | 06:22 PM
MrTodd's Avatar
Default Re: MPFI Swap: It runs (Jockobo)
good job...
Seriously - not very many people actually do a MPFI swap correctly!!!
Nice work, you know what's up.
Old Sep 23, 2002 | 06:44 PM
New User
Default Re: MPFI Swap: It runs (MrTodd)
Thanks guys, Im just enjoying the set up, but now Im looking into some mods. Is it true that the CRX header sucks compared to an aftermarket set-up. If this is true, it's time for a header!
Old Sep 24, 2002 | 08:46 AM
Finally Yimmy!
Damn right Danny boy!
Old Sep 24, 2002 | 09:13 AM
SohcVtecCrix's Avatar
a header is the best mod you can do to the crx......it made .3 difference in my quarter mile time....with I/e i was running 16.0 With a Dx trans...installed a pacesetterheader and i ran 15.5 the next day......i love D SERIES
Old Sep 24, 2002 | 09:16 AM
Stupid Ass's Avatar
Default Re: MPFI Swap: It runs (SohcVtecCrix)
Congratulations!
Old Sep 24, 2002 | 10:42 AM
New User
Default Re: MPFI Swap: It runs (SOHC NoTEC)
Hey guys, is the D16A6 camshaft better than the D15B2? If so, I can pick one up at the local junkyard for cheap. My car is a 91, so I not so sure if there is a difference in the years of the cams. I heard talk about the 88 cams not as aggressive as the 89-91, so if I pick one up I want to make sure the car is a 89-91.Plus is the cam key the same on all the D series? Will I be able to use the one off my cam for the Si cam? Thanks in advance.
Old Sep 24, 2002 | 11:12 AM
ZCivicTurbo's Avatar
Surging Idle usually means a wacky vacuum leak or a faulty MAP sensor or MAP sensor connection.
Old Sep 24, 2002 | 12:04 PM
Urban Business
Guest
Posts: n/a
a6 cam is better makes power to 7500rpm. however you will **** up the valves. by running to 6500rpm consistantly i recently fuct a valve seal and am burning oil like a ****. also what was wrong w/ your idle? glad you got your **** together
Old Sep 24, 2002 | 01:49 PM
New User
Default Re: MPFI Swap: It runs (TorteX)
the idle has been fixed. I just picked up the cam. Should I put it in or not? My redline is at 6500 and I don't even rev that high. Would it be ok for everday driving?
Old Sep 24, 2002 | 02:25 PM
zcivicz's Avatar
man i'm jealous i really wanna try it again but its getting cold up here so i think i will have to wait til next spring got any pics ??? the Si cam and the Si tranny makes a difference though and i'm still getting used to switching gears much sooner. although it pulls pretty good for a dpfi i still want my mpfi...
[Modified by zcivicz, 11:27 PM 9/24/2002]
Old Sep 24, 2002 | 02:58 PM
New User
Default Re: MPFI Swap: It runs (zcivicz)
Sorry, no pics at the moment. I need to find me an Si tranny. I think ill stay away from the cam untill I upgrade the valvetrain. I think a header and air intake will be up to bat next. I want everyone's opinion on what I should do next.
Old Sep 24, 2002 | 03:26 PM
New User
I want the best bang for the buck, besides the Si cam.
Old Sep 24, 2002 | 03:33 PM
b1reed's Avatar
hey b16awarrior i think i have all the parts needed to do this swap but im not really sure exactly how to do it.... is it possible for you to get ahold of me? i would appreciate it very much. i would love to do this swap but dont know exactly how....
b1reed@yahoo.com AIM: brandon15187 hope to be hearin from ya
Old Sep 24, 2002 | 04:17 PM
What did you do to fix ur surging idle? Mine is doing that right now. I was told that I need to bleed out my radiator. There is air in there somehow and that's causing it to surge....
-jimmy
Old Sep 24, 2002 | 04:45 PM
New User
Yeah, you might want to try bleeding the air out, but I don't think that's the problem. I would make sure you have all the vacuum hoses hooked up correctly. The problem I had was that the lock-up purge soleniod valve was not hooked up. aPlus reset your idle by ubplugging the IACV turn the throttle screw, cut car off, plug back in, pull hazard fuse for 10 sec, and your done.
