Allentown pa: EG hatch built b16/turbo/CF/fast/lots of goodies
Old Oct 31, 2010 | 09:48 PM
nolicense526's Avatar
Default Allentown pa: EG hatch built b16/turbo/CF/fast/lots of goodies
Chassis
94 civic hatchback cx
clean title, never in an accident
body needs some attention - right quarter has damage, no major rotting, hood has a dent and hole for wastegate
Carbon fiber duck bill
Carbon fiber Trunk
Skunk 2 front and rear Strut braces
Blox LCAs
Front Camber Kit
Alignment done by STS
Ground control coil overs with tokico illumina adjustable shocks
GSR front spindles with EBC gold drilled rotors
16" White racing wheels with new tires 205/45/16
cleaned and painted engine bay
new odysee race battery with password carbon fiber battery tray
Has a full interior, radio w/ 2 speakers
Grant Race Steering wheel
Skunk2 shifter and weighted ****
Engine
all the parts are almost new
B16 bottom end - JE 8.8:1 pistons, eagle rods, moroso oil pan, polished crank
honda water pump
honda oil pump
new tensioner and timing belt
B16 head CNC ported polished, valve bowls ported so that the valves sit flush
Stock valve train
ARP headstuds
GSR cams
Skunk 2 camgears
Custom valve cover - painted green with 2 -an bungs welded for breather
carbon fiber plug cover
new distributor
AEM fuel rail
Fuel pressure gauge
Skunk 2 intake manifold
Password jdm intake gasket
Custom Catch can
ebay motor mounts
aluminum race radiator and slim fan
LS hydro trans, 3rd gear syncro is bad in high rpms
new ACT race disc and maxx pressure plate
Aluminum lightweight flywheel
brand new reman axles
Turbo set up
p28 tuned on neptune
Drag cast iron manifold
t3t4 57 trim .63 a/r precission turbo
Real Tial 38mm wastegate with a 1bar spring
3 inch downpipe and straight exhaust with 1 3" resonator
2" hotside piping, nice size intercooler, 2.5" cold side piping
greddy type s BOV
750 RC injectors
GM 3 bar MAP sensor
Walbro 255 fuel pump
t bolt clamps
Russel oil drain -an fittings and stainless tubing
Russel oil feed stainless line
AEM Wideband
Autometer boost gauge
Autometer 5" tach
Autometer Oil pressure gauge
turbo xs boost controller
Will have more pics up later...
Price is $6500 or $6700 with a nice pair of almost new tenzo r seats...
call/text 6109058396
Old Oct 31, 2010 | 09:50 PM
Default Re: Allentown pa: EG hatch built b16/turbo/CF/fast/lots of goodies
its tuned by john at JKtuning in carisle pa. tuned to 18 pounds 362hp 258tq
Old Nov 1, 2010 | 08:30 AM
bump it ttt
Old Nov 1, 2010 | 02:07 PM
anyone want a fast civic???
SergieL
Jan 21, 2015 10:09 AM
nolicense526
Jun 4, 2011 08:20 PM
godeaten
Jan 27, 2009 07:47 AM
jdm_balla
Jan 24, 2008 10:32 PM
