main bearing clearances help!!
Old Oct 31, 2010 | 06:36 PM
ej93's Avatar
Default main bearing clearances help!!
ok ppl i just plastigage my main bearings and this is what i got
#1 .0015 #2 .0016 #3 .0019 #4 .0017 #5 .0017
what do u guys think thats with acl bearings let me know if thats ok
not too sure its my first build. thanks
Old Oct 31, 2010 | 07:46 PM
2point6's Avatar
Default Re: main bearing clearances help!!
Plasiticguage gets that accurate? who would have known...
Little tight IMO, but is within spec. I am assuming this is a "B" engine correct?
Old Oct 31, 2010 | 07:57 PM
ej93's Avatar
ya sorry about that ya its a b18b that im building
no its not that accurate lol i just took an educated guess
with the lil differences between the .0015 mark and the .0020 they were all in between
those two markes the .0019 was closes to the .0020 mark and the .0016 and .0017 were closer to the .0015 mark but not the same......
so is that good enough to leave it like that because i cant go oem bearings because the
crank was cut down and the bearings im using are acl race .25
Old Oct 31, 2010 | 08:06 PM
2point6's Avatar
Did you have the crank re-nitrided? If not I don't recomend using a "turned" crank.
Old Oct 31, 2010 | 08:14 PM
ej93's Avatar
im not sure about it being re-nitrated i bought it like that.....
but i dont know if i said it right but the crank journal was resized due to a spun rod bearing
is that what needs to be re-nitrated
Old Oct 31, 2010 | 08:21 PM
2point6's Avatar
IMO, yes. After it's "turned" you should get it re-nitrided. The factory does this stock and when it is "turned" you loose the hardening on it surface.
Old Oct 31, 2010 | 08:23 PM
ej93's Avatar
oh ok thanks ill check with the guy to see if he had it re-nitrated....
Old Oct 31, 2010 | 09:32 PM
Garage 808 Hatch's Avatar
swap the .0019, and .0015 bearings and remeasure. see if you can even them up
Old Nov 1, 2010 | 07:07 AM
unusual71's Avatar
hardening of the crank probably goes around 2-4mm deep how much material was removed from the journals. If it was only like .01" i wouldnt even worry about it.
also, the clearances look fine but plastigauge is not accurate to .000x i would say that your actual clearances would fall between .001 and .002 which should be fine.
Old Nov 1, 2010 | 10:13 AM
ej93's Avatar
Ok thanks for the info its greatly appreciated that's exactly what I needed Im gonna try and finish my build today
Old Nov 1, 2010 | 11:48 AM
2point6's Avatar
I feel that "unusual71" is mistaken on the depth of the Nitriding and if you choose to take his advice, I wish you luck on your build.
Nitriding is about 140 microns deep or .005" to .006". Turning the crank .010" will remove the surface hardening. Seeing that you posted that you are using .25 oversize bearings... well the math make sense to me. My advice is to get it re-nitrided.
Old Nov 1, 2010 | 01:59 PM
unusual71's Avatar
yeah my mistake on that, I originally thought the journals were hardened using a different method and I had nitriding confused with a different method which i thought was applied after . Without case hardening the crank is useless
edit: ^thanks for the professionalism i almost forgot i was on honda-tech for a minute lol
Old Nov 1, 2010 | 02:36 PM
ej93's Avatar
ya i dropped off the crank to get re-nitrided today thanks for that 2point6
Old Nov 1, 2010 | 02:41 PM
2point6's Avatar
Good to hear. After you get it back, do what "Garage 808 hatch" suggested for swapping the bearings to see if they even up.
Both "Garage808" and "unusual71" are right on with their clearance suggestions.
Hope it works out for you. Good luck
NoWorry's
May 27, 2013 09:03 AM
GReddy SI
Jun 6, 2012 09:31 PM
dallasyoung
Nov 2, 2011 04:53 PM
akura404
Jul 31, 2006 01:18 PM
Riceboy891
Aug 4, 2005 05:11 AM
