93 S13 240sx Coupe high compression Ka
Old Oct 31, 2010 | 02:16 PM
motormike40's Avatar
Default 93 S13 240sx Coupe high compression Ka 3300!!
I change the oil every 3500 using Mobile 1 10w-30 and use only 93 octane despite how painful fills up are.
no ac
hot heat
has power steering
Power windows and locks
Cons: Seam spilt on the bottom part of the S14 leather seat. There's a tear on the carpet on the drivers side floor. 1 crack on the dash and two chips on top of the gauge bezel. Carpet could use a shampoo.
Means of Contact: 678 977 1378
Year: 1993
Make: Nissan
Model: 240sx S13 coupe
Miles: 180,xxx on body,
Title: Clean GA Title
Price: $3300 FIRM
Vin: JN1MS34P1PW30XXXX
Exterior:
Clean stock body with pretty good paint and a pignose lip, oh yeah and ballin *** digi camo duct tape on eyelids and side mirrors.
Silvia trunk emblem that flips open for the key hole.
Interior:
Leather S14 seats, interior is not bad and it is all complete.
Alpine head unit
Aftermarket front speakers
Alpine type S 6x9's in the rear
Engine:
Previous owner built the engine.
Ka24de ~11:1 compression ratio
bottom end was bought new from the dealer Ka24e pistons, rods, and rings.
I have photos of the compression check and it's 190 psi across all 4 cylinders.
Electric fan, not too sure what CFM, but it cools the engine fine.
"hot cam" swap 248 degree intake, 232 degree exhaust.
Injen short ram intake
unknown brand header
Megan cat back exhaust with test pipe
Walbro 255 fuel pump
Battery in the trunk
Msd Blaster coil and msd sport compact ignition box
Ported and polished head with port matched intake manifold and throttle body
New timing chain & tensioner, new seals throughout
1 inch steel braded lines to a front mounted external oil cooler
Tuned on Apexi Neo, I do not have the dyno sheets but I was told it put 193 whp and 185 trq. Feels very very good.
Wheels:
Stock S14 rims with good 205/55/16's all the way around.
Suspension:
Tein springs and Tokio blues on all 4 corners
Unknown brand front strut tower
Drivetrain:
I was told it had an Exedy stage 1 clutch, but I never separated to varify what brand, however it is definitely staged.
Unknown brand short throw shifter
It has an open diff in the car, I will throw in another open diff to get welded.
J30 front breaks
S14 5 lug conversion
Old Oct 31, 2010 | 02:17 PM
Default Re: 93 S13 240sx Coupe high compression Ka
Old Nov 3, 2010 | 10:45 AM
3300!!!!!
motormike40
Nov 3, 2010 10:44 AM
coopn8r
Jul 1, 2010 10:48 AM
b20accord
Mar 22, 2007 09:48 AM
J_J
Jan 7, 2006 06:36 PM
J_J
Jan 3, 2006 03:12 PM
