which coils to use? motec m8 + aem epm?
Old Oct 31, 2010 | 12:12 PM
RACEPAK's Avatar
Default which coils to use? motec m8 + aem epm?
hi guys,
i upgraded my M4 to a M8 and i will be using a AEM epm for trigger on my D16.
i'm not sure yet on which coils to use, CBR's? or maby stock k20 if they are the same size as the 2001 civic coils,
any advice? whats the part number of the cbr coil everyone use?
thanks
Old Nov 1, 2010 | 10:14 AM
RACEPAK's Avatar
Default Re: which coils to use? motec m8 + aem epm?
up?
Old Nov 1, 2010 | 11:26 AM
tepid1's Avatar
CBR's (1000RR kind) will work, but I'm not sure how you'd get them to hold down. You'll have to fab up a plate of some sort to hold them down.
Old Nov 1, 2010 | 11:30 AM
cluelessmale's Avatar
If they are CBR coils they need the plugs that you can remove the tops from, so they kinda hold themselves down
Old Nov 1, 2010 | 11:34 AM
B18c1turboedEK's Avatar
I would get the Aem coils. They pay for themselfs, too run the Cbr coils you have too run the NGk Irdiam plugs that cost 8 each.With the Aem coils you can run regular ngk plugs.
Old Nov 1, 2010 | 11:47 AM
h22 civic's Avatar
i have a epm and aem coils if your interested.. the epm is a nice peice for sure
Old Nov 1, 2010 | 12:00 PM
tepid1's Avatar
If you use the AEM coils then you can't use an M&W ignition.... which I do believe he is using....
Old Nov 1, 2010 | 12:13 PM
I know someone that was using the M&W Pro4 with them, so I would believe it would work.
Old Nov 1, 2010 | 12:37 PM
RACEPAK's Avatar
thanks for the answer,
which aem coils fit on the d16? the long ones or short ones?
Old Nov 1, 2010 | 12:40 PM
RACEPAK's Avatar
hi,
no i'm not using a m&w, i dont need it, i have 8 ignition outputs on the m8.
Old Nov 1, 2010 | 12:56 PM
tepid1's Avatar
Then what are you going to use? You need a driver like the AEM twin spark or the M&W to make the spark....
The Motec is just a trigger for the spark.
Old Nov 1, 2010 | 12:58 PM
tepid1's Avatar
It's not good for the AEM coils due to the type of coil it is. CBR coils are what's correct for use with the M&W.
Old Nov 1, 2010 | 02:32 PM
Turbo-charged's Avatar
cbr coils hold themselves into place no problem with proper plugs
MR.johnson
Aug 29, 2011 03:23 AM
b22vtec
Engine Management and Tuning
Mar 22, 2010 07:53 AM
ebydrc
Mar 12, 2009 05:10 PM
slvrstns2000
Feb 19, 2004 06:56 AM
