d16 new PB 10.74
Old Oct 31, 2010 | 11:43 AM
t66crx's Avatar
Default d16 new PB 10.74
Well this whole season i had lots of problems with the car and had to use stock sleeves d16z6 with vitara pistons. we had my 42r break back in july when it sucked the screen into the turbo. took some time to look throught every log i had from the season and came to the conclusion something was wrong with my distributor. well i took it apart and the tdc piece on the shaft was loose and moving around and the end that goes in the cam the pin was almost worn away. so put a new one on and put a small fram T04B 60trim on the car.
went 10.74 @ 134.69 and backed it up with a 10.92 @ 133.07
This was also at 4800ft
http://www.youtube.com/watch?v=kyc02NQL2HA
http://www.youtube.com/watch?v=RqeGsIaZtCo
Old Oct 31, 2010 | 12:58 PM
Terrible One's Avatar
Default Re: d16 new PB 10.74
600hp on stock sleeve d16z6? sickkkk
Old Oct 31, 2010 | 02:06 PM
joe111599's Avatar
What clutch are you using? Thanks!
Old Oct 31, 2010 | 02:27 PM
t66crx's Avatar
no the 600hp was on a sleeved block but a rod went throught the block on the dyno at 7200rpms so didnt hit my rev limiter even.
clucth is a clucthmasters stage 5 4puck with the dual stacked pressure plate
Old Oct 31, 2010 | 03:05 PM
xenocron's Avatar
At that altitude I'm super impressed!
Congrats!!!
Old Oct 31, 2010 | 03:32 PM
neek175's Avatar
Congrats on your pb. Can you give us more of a breakdown of this setup. Headwork, cam etc? How many lbs of boost?
Old Oct 31, 2010 | 03:33 PM
CO_RaceFab's Avatar
Good job todd running in colorado aint easy
Old Oct 31, 2010 | 03:38 PM
Kyle R's Avatar
Old Oct 31, 2010 | 04:02 PM
t66crx's Avatar
Ya at this altitude is very hard to run good times. Boost levels was around 30-34psi. traction was not my friend though on 2 year old slicks
the engine
d16z6
stock sleeves
59500 cam
port matched head
KMS springs/retainers
vitara pistons
eagle rods
custom intake manifold w/90mm throttle body
air/water intercooler 3" on hot side 4" on cold side
hondata S300
NO wastegate
Old Oct 31, 2010 | 04:07 PM
t66crx's Avatar
here is a few pics of the setup
Old Oct 31, 2010 | 04:30 PM
92redhatch's Avatar
What's the breakdown on the slip? And no wastegate? How do you control boost
Old Oct 31, 2010 | 04:33 PM
1991civicsi's Avatar
SOHC FTW!
Old Oct 31, 2010 | 04:46 PM
t66crx's Avatar
1.719
4.710
7.067 @ 103.86
9.070
10.740 @ 134.69
1.739
4.792
7.195 @ 101.69
9.235
10.928 @ 133.07
Old Oct 31, 2010 | 04:47 PM
t66crx's Avatar
Dont need to control the boost with it. just make as much boost as possible
was makin 31.2psi on 2step
Effective Altitude 6963.00 ft on the 10.74 run
Effective Altitude 7451.00 ft on the 10.92 run
Old Oct 31, 2010 | 05:50 PM
luck4rmkc's Avatar
^That's insane! Launching at 30psi! I have never even heard of anyone ditching the wastegate and just maxxing the turbo out...
Old Oct 31, 2010 | 06:07 PM
Autoworks's Avatar
Congrats!
Old Oct 31, 2010 | 06:14 PM
t66crx's Avatar
yeah 30psi for launching seems alot too people considering most everyone i see is only around 8-15psi.
thanks. cant wait till next season with the new sleeved block and the 42r and 40psi
Old Oct 31, 2010 | 06:29 PM
Topoyiyo's Avatar
Nice, reminds me of when I welded the wastegate shut on my moms 93 turbo capri LOL. That thing must feel lit
Old Oct 31, 2010 | 07:12 PM
reddcoupe's Avatar
congrats on the pb the sleeve block that broke what sleeve u had
Old Oct 31, 2010 | 07:38 PM
t66crx's Avatar
it was a golden eagle sleeved block. i spun a bearing and thats what caused that
Old Nov 1, 2010 | 04:55 AM
RACEPAK's Avatar
sweet
Old Nov 1, 2010 | 02:59 PM
welfarepc's Avatar
huge top end on that thing.
its got so much more in it with some work to the short game.
nice.
Old Nov 1, 2010 | 05:20 PM
t66crx's Avatar
nice.
ya i need some new slicks and then i think it should do a .40 or a .30. on the datalog it was spinning in 4th gear and all gears
Blacknight117
25
Mar 6, 2011 05:42 PM
4ghatch
Apr 24, 2008 09:00 AM
G U E C O
Sep 27, 2005 05:21 AM
cueballsi
Aug 30, 2005 12:09 PM
methos713
Northern California (Sales)
Jun 24, 2005 10:33 PM
