EM2 Apexi Neo Help
I installed an Apexi Neo AFC controller on my 2001 Civic LX about 2 weeks ago and I didnt have time to wire it completely so I just wired the IG power, Ground, Throttle sensor, and the RPM sensor. It ran great no problems what so ever, so this weekend I came home from college to finish up the wiring by connecting the Air Flow and Pressure sensors (Yellow and White wires) and at first I didnt realize that Pressure Sensor had to be set to 6 In and 6 out on the Neo so then it was running fine. After that I went back and cleaned up the wiring after removing the CEL and now the Neo wont even turn on. I've tried everything today but the Neo wont turn on and the car wont start. I tried removing the old solder, diode testing on all the wires, but the controller wont turn on. Even with the Air Flow and Pressure wire NOT running to the Apexi, and running directly to the ECU like it did before the controller, my car still wont start. It does turn over, but my guess is that since I set the Apexi to 6 in and 6 out that my ECU is looking for the Apexi's signal that isnt there since it wont turn on. I'm running out of ideas. And thoughts or ideas would be greatly appreciated.
Thank you,
Thank you,
