SAFE MODE HELP! LSVTEC
Old Oct 30, 2010 | 06:06 PM
beamer's Avatar
Default SAFE MODE HELP! LSVTEC
I changed my headgaket and now the car is on safe mode... i dont know what i could of done wrong! So can someone help me out here... Car was fine now on safe mode.
Old Oct 31, 2010 | 10:40 PM
mouab18c1's Avatar
Default Re: SAFE MODE HELP! LSVTEC
Whats safe mode? Did you install everything correctly? Mismatch connectors?
Old Nov 1, 2010 | 01:17 PM
beamer's Avatar
It won't let your car pass 3500 rpm. Evrything was connected fine!
Old Nov 1, 2010 | 01:50 PM
mouab18c1's Avatar
Did you double check that you didnt mismatch the map and tps sensor?
Old Nov 1, 2010 | 02:56 PM
beamer's Avatar
No there right but now I got codes like crazy. I got code 19 which is for the injectors and that's what's putting my car in limp (safe) mode. There all connected fine.
I also have somewhat a misfire on cylinder 2. I have spark but it doesnt seem strong and it doesn't bog when I pull the wire out. It's not the spark plug because I swapped them and it's not that.
Old Nov 1, 2010 | 03:07 PM
mouab18c1's Avatar
You have two threads. Just post in one of them
Old Nov 1, 2010 | 03:10 PM
beamer's Avatar
The other thread
boostedD
Jan 15, 2008 02:46 PM
harshhatch1187
Oct 6, 2006 10:22 PM
EvilPinkEye
Sep 1, 2006 10:20 AM
EckoTech
Sep 30, 2005 08:43 PM
GDM Z28
Feb 9, 2004 03:45 AM
