What cc injectors for 12.7-13.0:1 compression?
So b18c1 block, b18c5 head, jdm pct b16b pistons. According to some other members and a compression calculator its about 13.0:1. I know the stock b16 injectors I have are to small so I was wondering what you guys would recommend. Motor is in a track car and will always be fed 110 octane gas. Road race car, not drag race just for reference. Thanks Guys.
Car is still obd0 and I'm not converting it to obd1 to tune it. Im going to throw in bigger injectors, get a wideband o2 with an exact number afr and keep an eye on it. probably after market fpr and fuel pressure gauge as well. To be able to mess with the fuel pressure a little bit.
A FPR will only control so much, your wasting your time and money if you dont tune it correctly and you risk alot of other things..
Stock injectors are fine, if your able to tune it.. i run 440cc's on my 13.0cr b20vtec... again, i'll restate, convert it to obdI, its not hard.
Obdo has excellent tuning software available btw. Its called BRE. ALL MOTOR, have you ever used it? I love it, in fact, if BRE was avail for obd1 rpms, I would use that over crime pro anyday.
your using software that hasn't been updated in 3 or 4 years.. at least crome was updated...
i used bre, to tune a few DA integras back in the day, i dont touch it now..another program i betaed.
If a OBD0 car comes to me and needs to be tuned, its converted to OBDI..otherwise i wont touch it.
ya, you can also use ecucontrol or turboedit as well
One main reason is the fact that you get more sensors to tune off of, and not to mention, coding is different.. as you know there was crome tuning issues in really , really early versions of crome.. and with that, alot of people forgot about the dwell ign coding, and uberdata's dwell ign correction from what i know its hit and miss.. I've tuned bolt on DA's with ls's and some XSi b16a swapped DA's with uberdata. Its good for that, but if you go indepth in your setup like turboing.. you need to upgrade.
Im a big supported of DIY, and PGMFI.org.. we all know that, i've said it a ton of times.. but i dont want people to get the idea that using outdated **** is ok..uberdata is wayyyyy outdated compared to crome.
Dont forget about B.R.E neither
I've never had any issues since 1.5.3+ with crome connection issues. With that said, there's a few reasons to swap from OBD0 to OBD1.
Im running the most up to date version of crome pro. And I receive connection errors. And what sensors are we talking about that are different? They both have iacv, tps, map, iat, o2, 4 injectors, knock, oil pressure, tdc sensor, cyp sensor, ckp sensor.....am I missing anything? Only difference between obd0 and obd 1 that I can think of is 4 wire vs. 1 wire o2.
And dizzy hookup.
crome pro? or crome pro GOLD?
ya i mean.. who wants to do things correctly, lets just half *** it.
OP,
All-motor is correct, OBD-1 is going to be the better than OBD-0. The only problem I had with BRE was trying to use large injectors on start up.
As for your cost, I don't know about $1200. You should spend more like $600 without tuning. Plus unless you plan to run a stand alone or the integra is already OBD-1, the only thing you will lose is the cost of a harness which is about $100 from any dealer on here. Everything you have to convert on car you can use on the new car. Also, I don't understand the comment about the wideband. If your car is running with a wideband then you can use it on Neptune. If the car is not using a wideband then why do you need now?
To convert my car, I used a chipped P28 tuned with Netpune, prelude 370 OBD-1 injectors, OBD-2 dizzy from a GSR, and LMA-2 wideband from innovative.
Also, if I were you, I would run the RDX injectors or ID1000s and E85. That will keep you from running lean and you will be able to run max timing and keep the engine cool.
OP,
^^^High compresssion on small cams is a recipe for engine failure especially on stock timing and long periods of WOT operation. Without increasing overlap, you will most likely have another engine failure.
By increasing overlap do you mean increasing timing? And why is it a recipe for engine failure?
Wait a sec... how will a 10.8ish:1 comp LS with b16 pistons with built head and stock cams fair for break in untill I put in BC stage 2's and get it tuned? Not meaning to thread jack just curious?
1200 dollars to convert over???
You need a dizzy, new injectors and a obd1 ecu.. and wire in vtec, the dizzy / injectors can be found for little..
hell there are 440cc's around here for 120 and new oem dizzy run what, 160? you might spend 400 converting over..maybe..
Whatever dude, you posted asking for information, we're all giving you the route you should take.. you ARE half assing it... specially this high of compression.. i'd re think the setup if your going to stick with a OBD0 ecu..
All motor wise, you can make decent power using bre or turboedit.
No, overlap is the event when both the intake and exhaust valves are open at the same time. This will contaminant the intake charge with spent gases and increase its resistance to detonation. Also, yes you will need to adjust timing.
Lol. Look and at your engine and you tell me.
