D16A9 Electrical problem?
Old Oct 30, 2010 | 07:14 AM
CRtotheX's Avatar
Default D16A9 Electrical problem?
My D16A9 does not crank over, the starter doesnt make a noise, the fuel pump engages though.
On to the problem :
I crank the key over and on the dashlight my right+left blinker light and foglight are glowing, but the lights on the outside are not on.
This is just when i crank the key over to start it.
I push startet the car and i fired up, but the dashlight blinkers and foglight was glowing.
Any hints or tips?? Need the car as daily driver right now.
Old Oct 30, 2010 | 01:44 PM
stella88's Avatar
Default Re: D16A9 Electrical problem?
hmm 25 views & no replies! Short possibly? loose ground connection? Double check on connections on your starter & lights Im not to good with electrical issues, but these are the things I would check first.
Old Oct 31, 2010 | 03:56 PM
eazy64's Avatar
could be a neutral safety switch. if its stick its behind the clutch pedal.
94turbo
11
Jul 3, 2009 05:02 AM
PhantomX
Apr 6, 2008 09:15 AM
kyorishin
May 3, 2007 09:53 PM
VSM3point5genDC4
Jan 20, 2004 09:55 AM
