Suspension & Brakes Theory, alignment, spring rates....
Do I need shorter/lowering springs with Bilstein Sport?
Old Oct 30, 2010 | 05:03 AM
EBPSI's Avatar
Default Do I need shorter/lowering springs with Bilstein Sport?
I recently received my order of Bilstein Sport for my 1999 Civic.
After doing some reading, it seems that the Sport version of the Bilstein shocks are about an inch shorter than the HD version. Do I need to purchase new springs to properly accomodate the new shocks, or will they be just fine on stock springs? I really don't want to lower the car if possible, the roads I live around and travel on, aren't exactly perfect and it's rough enough as it is without the car being lower.
In case I "must" need a shorter/lower spring, does the ITR springs fit a 1999 Civic Si without any modification? If so, are the ITR springs shorter than 1999 Civic Si springs?
I've been out of the loop around here for a while, and I've forgotten a lot of information, any help with this is greatly appreciated
Old Oct 30, 2010 | 06:42 AM
Libertariat's Avatar
Ek Forever y0!
Default Re: Do I need shorter/lowering springs with Bilstein Sport?
ITR springs wont fit your 1999 Si. CTR springs however will.
Old Oct 30, 2010 | 12:28 PM
EBPSI's Avatar
Thanks for the advice, lesson learned.
Are CTR springs slightly lower than stock SI springs?
Old Oct 30, 2010 | 09:42 PM
Ek Forever y0!
Height I'm not sure of. but the Spring rates a significantly better than Civic Ex/dx/lx/cx.
Might not be much of an upgrade from si springs.
There's a factory springrate list stickied at the top of the suspension forum.
Old Oct 30, 2010 | 09:57 PM
98civdx's Avatar
Master Detailer
Yes, CTR springs are shorter then regular springs, not to mention different spring rates as already said. The springs will lower it 1 inch, but some say .75"
When i had them on my car, it was 1"
After looking reall quick, i found CTR springs are 240lb front and rear, and are linear front, progressive rear
And the Si is 201lb front, and 100lb in rear. And both are progressive.
Old Oct 31, 2010 | 08:00 AM
bsmith100's Avatar
The stock springs will work, however the spring rates are a bit soft.
Old Oct 31, 2010 | 05:34 PM
92civiceg9gsr's Avatar
Yes you can use your stock springs. With the bilsteins your car will have less droop travel but will have more compression travel.
Old Nov 1, 2010 | 10:26 AM
EBPSI's Avatar
Thanks for the replies guys.
Will be using the stock springs for now.
SOLO1racer
20
Sep 7, 2007 08:03 AM
power11
May 15, 2007 11:02 PM
vermilion
Suspension & Brakes
Aug 1, 2006 01:14 AM
LillDragun
Mar 25, 2003 11:35 AM
Julian
Jun 2, 2002 10:48 AM
