ProDrive B-series oil pump gear
Only used during one dyno session. Ended up changing projects so I put the stock oil pump back together. Still in perfect working condition. Fits any B-series oil pump GSR, B16, LS, B20, or ITR $125 shipped + 3% if paypal is used.
Per Prodrive/Circuit Worx: "Oil Pump gears are precision machined and ground out of solid steel to insure longer life than OEM gears. These billet oil pump gears are much stronger than a stock gear and will withstand high RPM vibration much better than a stock unit."
