Will these ac componets work on...
Old Oct 29, 2010 | 01:04 PM
ScoobyJD's Avatar
Default Will these ac componets work on...
I just bought an AC compressor and condensor from a guy who pulled them off of his 99 honda civic. Will these work on my 91 civic?
Old Oct 29, 2010 | 05:22 PM
fcm's Avatar
fcm
Old Fart
Default Re: Will these ac componets work on...
As long as the fittings are the same, the 91 Civics A/C lines, [fittings] must fit the 99 Civics compressor, [manifold] and the condensor fittings.
The compressor must be "mountable" so pulley will line up.
With that said, your 91 is an R12 system and the 99 is an R134a system, different refrigerants, this does not mean they can't be made to work.
I will check at work tomorrow to see if the compressors are the same... http://airwolfeautoair.com/ 94
Old Oct 30, 2010 | 09:26 AM
ScoobyJD's Avatar
Thank you, I appreciate it!
Old Oct 30, 2010 | 04:16 PM
fcm's Avatar
fcm
Old Fart
Chit, posting did not work at work, all that typing.
Anyway, there are two diff. comp. used on the 91, depending on engine size.
There are two diff. comp. for the 99
You can look them up hear... http://www.4s.com/Online%20Catalogs-...g/Content.aspx put the cursor over the part number to see the compressor, you will see the manifolds are diff, mounting of the two 91 comp. is diff., the two pulleys are diff.
The two 99 comp use the same mounting, [same engine] but the pulleys and manifolds are a little diff.
Mods will be needed to install either of the 99 comp. on your 91. 94
Old Oct 31, 2010 | 02:13 PM
ScoobyJD's Avatar
So I am pretty much screwed and have to buy a complete system from a 88-91
Old Nov 1, 2010 | 05:53 AM
fcm's Avatar
fcm
Old Fart
Not necessarily, what is in the car now? is it a 91 Civic A/C system and is it complete?94
Old Nov 1, 2010 | 12:30 PM
ScoobyJD's Avatar
I have every thing behind the firewall with the two short ac lines sticking out of the firewall. I also have the canister.
Old Nov 1, 2010 | 04:21 PM
fcm's Avatar
fcm
Old Fart
Then as long as you can mount the compressor properly, you can get the compressor suction and discharge lines, [hose assemblies] from four seasons... http://www.4s.com/Online%20Catalogs-...g/Content.aspx that fit the compressor you have.
The other ends of the two compressor lines may or may not fit the 91 components, [they may have to be changed]. 94
Old Nov 4, 2010 | 12:31 PM
ScoobyJD's Avatar
So I might as well just sell these and just start from scratch at a junk yard. less of a head ache any way lol.
Old Nov 4, 2010 | 04:16 PM
fcm's Avatar
fcm
Old Fart
It is what I would do. 94
Old Nov 5, 2010 | 11:09 AM
ScoobyJD's Avatar
Thank you man, I really appreciate the information. It is definitely going to save me a lot of head ache.
Dragonsfire
Jul 1, 2018 02:35 PM
wulffboy1989
Jun 11, 2014 01:38 PM
83rolla
Jul 25, 2012 07:54 PM
carlosd68
Aug 7, 2005 12:48 PM
