Few Questions about after-market suspension setups
Old Oct 29, 2010 | 12:13 PM
SlammedDC2teg's Avatar
Default Few Questions about after-market suspension setups
I am by no means a noob when it comes to suspensions, but I do have a couple of questions to ask about my 96 Accord LX.
I have been looking into lowering my car on a budget, this is my daily and has over 220k, so keep that in mind. I'm looking to run CG/Koni's.
My question is, Are Accords prone to heavy camber as a result of lowering about 2'' all around? Kinda like the DA's and older EF's
I'm trying to get away with running no camber kit lol, so I would like to know if I need one.
Also, I plan on running a RSB, I found out Progressive makes one for our cars, is any one running one?
what setups are you guys running? Do you recommend them? Pics would help. Thanks
I chopped a photo from earlier today to the height I wanted to run, for reference.
Old Oct 29, 2010 | 12:22 PM
TheMuffinMan's Avatar
He knows where you live!
Default Re: Few Questions about after-market suspension setups
Why would you need a camber kit? You honestly never *need* one other than for looks.
Just have the toe zero'd out with the alignment
Old Oct 29, 2010 | 12:30 PM
Yeah I know I can do that, I just don't want to run more than -2 degrees of camber on a daily because eventually you will start to see some wear.
Old Oct 29, 2010 | 01:04 PM
Nope, one of those urban myths. Provided your toe is 0.0 degrees (or as close to that as possible) you will be fine and minimize any type of premature wear.
The other thing to keep in mind is the anchor style camber kits will cause the UCA to hit the inner fender well. You're better served with the ball joint ones.
datruf_vtec
Aug 27, 2014 08:07 AM
JDM04Si
Jul 20, 2009 08:24 PM
cortrain
Suspension & Brakes
May 29, 2008 10:40 PM
Group 03
Feb 20, 2003 07:48 AM
