tach signal wire a/f gauge signal?
Old Sep 20, 2002 | 05:33 PM
Cereal_Killer's Avatar
Default tach signal wire a/f gauge signal?
what pins ate ECU. car is a 1991 CRX DX>
Old Sep 20, 2002 | 08:34 PM
MADEINIRAQ's Avatar
Default Re: tach signal wire a/f gauge signal? (91EFZC)
pin C16 on the ecu.
the 3rd "plug" on the ecu.. the small black one with 16 wires on it. the lowest(closest to floor) "plug" on the ecu when it's installed
white wire
Old Sep 20, 2002 | 09:32 PM
Default Re: tach signal wire a/f gauge signal? (madeiniraq)
ok so which is that for, the tach or a/f gauge ?
Old Sep 20, 2002 | 10:51 PM
B20zvtecek's Avatar
go to http://www.hasport.com under Tech Info , they got a diagram for ecu pin outs
Old Sep 21, 2002 | 04:00 AM
keithv's Avatar
Default Re: tach signal wire a/f gauge signal? (B20zvtecek)
you are better off tapping the o2 wire at the o2 sensor and not the ecu...
spoonzdelsol
Oct 4, 2005 12:40 PM
vtecb20coupe
Oct 6, 2004 05:02 PM
crucial si
May 27, 2003 06:35 PM
IgniteTeg
Aug 20, 2002 08:13 PM
A11MotorR
May 22, 2002 12:22 PM
