Suspension & Brakes Theory, alignment, spring rates....
SUSPENSION PROBLEM
Old Oct 28, 2010 | 11:48 PM
dpacheco's Avatar
Default SUSPENSION PROBLEM
Delete
Old Oct 29, 2010 | 10:37 AM
ej6kid's Avatar
Default Re: SUSPENSION PROBLEM
Can be numerous problems. how many miles are on your car
Old Oct 29, 2010 | 11:49 AM
dpacheco's Avatar
about 130k
Old Oct 30, 2010 | 07:44 PM
ej6kid's Avatar
Check your ball joints. rack and pinion, or maybe even something in the steering column? My old accord used to shake pretty bad when i would get into higher speeds. Changed some bushings and ball joint, upper control arm, end of that noise, Dont quote me on it though, that may not be your issue
Old Oct 30, 2010 | 08:00 PM
dpacheco's Avatar
thanks alot i really appreciate the input. thats the stuff im looking for. ill check on that stuff tomorrow
Old Oct 30, 2010 | 08:34 PM
ej6kid's Avatar
Yeah when you jack your car up, try and shake the wheel like top to bottom, idk its hard to explain, try and make it like your making camber on your car with your hands? haha idk if theres play in that then you know it can be one of those things, your wheel should only go left and right not up and down lol
Old Oct 31, 2010 | 08:08 PM
dpacheco's Avatar
ttt
Old Oct 31, 2010 | 10:42 PM
98civdx's Avatar
Master Detailer
uh, my friends old car shook like crazy and we could never ever figure it out.
Is this a new issue that showed up when you lowerd your car? Did you have it aligned?
As he said, check your ball joints and tie rods. Its doesnt cost all that much to replace them, really. They can make quite a difference.
Old Nov 1, 2010 | 01:52 AM
ddongbap's Avatar
Are your tires balanced?
hardcore97
Suspension & Brakes
Dec 22, 2013 06:27 AM
v8Buster
Jan 2, 2007 09:16 PM
work-in-progrex
Suspension & Brakes
Oct 12, 2005 02:20 PM
SETI20
11
Sep 11, 2005 04:16 PM
Spade
Jun 20, 2002 07:43 AM
