Engine stalled for a second on the highway
Old Oct 28, 2010 | 11:28 PM
ElephantMan13's Avatar
Default Engine stalled for a second on the highway
So I was driving on the highway going about 70mph, then I noticed the motor died for a second (rpm dropped to 0 and no response with the throttle,) then it just came back to life like nothing happened. I thought this was normal before when I had a faulty main relay and the car would have a hard time starting on hot days and sometimes even dying, but i havent had any of these problems once i switched out the main relay. Could something else be wrong?
Old Oct 29, 2010 | 04:57 AM
4norzn's Avatar
Default Re: Engine stalled for a second on the highway
checked the battery and alternator output?
maybe a loose connection on the alternator (happened to me) thats not charging the battery?
Old Oct 29, 2010 | 07:04 PM
thusee's Avatar
could be the distributor on the way
Old Oct 29, 2010 | 08:54 PM
miamijdmcoupe524's Avatar
If this is a 5th gen. I believe honda has a tsb for the ignition switch. It causes the car to die and than come right back on. Look it up if it is..
Old Oct 30, 2010 | 12:41 AM
Sorry i should've clarified, this is a 4th gen. Thanks for the suggestions guys, I'll look into one at a time.
aqprider
Sep 1, 2013 02:01 PM
turboteg90
Nov 15, 2009 05:26 PM
Ash J. Williams
Jan 20, 2004 05:27 PM
dumbchild
Sep 3, 2002 03:25 PM
