4th Gen Headlight level adjustment
Old Oct 28, 2010 | 09:49 PM
ElephantMan13's Avatar
Default 4th Gen Headlight level adjustment
My driver side headlight is aiming a little high. I located the adjuster but do not know which way to turn to lower it. I tried both ways, but no matter which way I turn, the beam seems to be going higher and higher. Does anybody know definitively which way I'm suppose to turn it to lower it? Thank you guys in advance.
And yes I read the owners manual and searched before I posted this thread. Neither of which tells me which way I'm suppose to turn it.
Old Oct 28, 2010 | 10:35 PM
Default Re: 4th Gen Headlight level adjustment
Nobody up at this hour? Guess my adjustments will have to wait till tomorrow!
Old Oct 29, 2010 | 06:39 AM
minilogoguy18's Avatar
Pretty sure counter clockwise lowers them, your gonna have to do this at night close to a wall and it's gonna take a bit of turning before you notice they've moved at all.
Old Oct 29, 2010 | 07:11 AM
sde780's Avatar
are you adjusting the top or bottom adjuster?
top one affects side to side movement more than up/down in the bb6 headlights.
bottom one is the one that adjusts height
Old Oct 29, 2010 | 07:15 AM
Uuummmm, the one where I look straight down into. I only managed to locate one of them.
When you say counterclockwise, do you mean the gear or the Phillips should be turning the way?
Old Oct 29, 2010 | 09:18 AM
Well first of all you never even said which gen Prelude you have, and second the USDM and JDM 4th gen headlights are different in the way which they adjust.
Old Oct 29, 2010 | 10:34 AM
4th gen. Said so In title
Old Oct 29, 2010 | 10:37 AM
Yeah I'm dumb. =p
Well, USDM or JDM lights? They adjust differently.
Old Oct 29, 2010 | 11:02 AM
[QUOTE=minilogoguy18;43891634]Yeah I'm dumb. =p
Well, USDM or JDM lights? They adjust differently.[/
just the stock usdm
Old Oct 29, 2010 | 12:10 PM
jkoni426's Avatar
looking at the helms, the vertical adjuster is on the top right by the fender. I couldn't figure out how to just copy and paste from the online manual, so here's an attachment:
File Type: doc
AtoZ
Nov 27, 2009 09:25 AM
samkim0108
Nov 12, 2009 06:05 AM
Importn2oRacer
Oct 26, 2008 12:46 PM
2000h22a
May 31, 2008 11:33 AM
markyh
Nov 18, 2006 08:15 PM
