clutch issues
Old Oct 28, 2010 | 09:13 PM
tercelrcr's Avatar
Icon2 clutch issues
So my brother in law has a 97 accord ex 2dr coupe with a 2.2 vtec motor and 5spd trans. He let go of the clutch on accident when parking it and it jumped like a manual does when you release the clutch with no gas. He got up to go to work today and the clutch pedal goes all the way to the floor with no resistance but it comes up on its own. The car starts when the clutch it pushed in but will not go into gear while the car is running. Im thinking its either the master or slave cylinder. any ideas ???
Old Oct 28, 2010 | 09:17 PM
tamadrummer1120's Avatar
Default Re: clutch issues
it could be either. best thing to do first is look for leaks. and if either one is culprit, go ahead an change both.
Old Oct 28, 2010 | 09:23 PM
bseriescrxsi's Avatar
the clutch is on a spring so it WILL come back up on its own in most cases and the car starts on a sensor that only senses pedal position not engagement...the slave cylinders on these cars are infamous at going bad i would suspect that is your culprit....replacing the master is a little harder but you could still replace it just to be safe
Old Oct 29, 2010 | 04:30 AM
nus_dogg's Avatar
I'd check the carpet under the dash just right under the clutch pedal for leaks then look at the slave to see if there's any seepage or wetness around the slave cyl boot.
blacklabel14
Feb 3, 2011 12:32 PM
markski037
Dec 21, 2005 05:13 PM
iwreakhavoc
Jun 3, 2005 10:47 AM
FLCivic
Jun 30, 2004 03:48 PM
VTC_CiViC
Nov 17, 2003 08:10 AM
