Tryed searching if a k20z1 crankshaft will fit in a k20a2 block
Old Oct 28, 2010 | 08:27 PM
ivanson's Avatar
Default Tryed searching if a k20z1 crankshaft will fit in a k20a2 block
long story short. my friend blow his 02 type s
took to machine shop.
needs a crank and oversize the pistons.
possible weld and grind the crank, but its not guarentee that
it will last.
found a k20z1 crankshaft in mint condition and cant find
any info if its a direct fit on the k20a2 block.
any help will be appreciated.
thanks
Old Oct 28, 2010 | 08:38 PM
Type-Spaz's Avatar
DC5/EP3 MOD :)
Default Re: Tryed searching if a k20z1 crankshaft will fit in a k20a2 block
It will fit sir. Direct swap
Old Oct 29, 2010 | 08:55 AM
ivanson's Avatar
great. thanks.
Old Oct 29, 2010 | 09:18 AM
nahonda04's Avatar
Surje.motorsports
may want to measure bearing size again thou or you can check the sub-block that the crank came out of to see what bearings were used originally...either way i would still measure and get new bearings
Old Oct 30, 2010 | 10:14 PM
ivanson's Avatar
yea im going to get all new bearings and rings
heres a picture of the one im trying to buy.
but i just notice something. are the gears pressed in on the
k20z1 crank?
my a2 crank may look diff. cant see it since its at the machine shop.
Old Oct 31, 2010 | 02:13 PM
hawaiiancb74's Avatar
no he just happens to have the chain gears and the cam sensor plate and bolt on it.. they all slide off when the bolts not in the way
Old Oct 31, 2010 | 07:37 PM
ivanson's Avatar
ok cool. thanks
Old Oct 31, 2010 | 07:38 PM
ivanson's Avatar
anyone got a good site for over sized pistons. for oem application.
Old Oct 31, 2010 | 09:00 PM
nahonda04's Avatar
Surje.motorsports
http://realstreetperformance.com/store/
they are in the market place on HT too
Old Nov 1, 2010 | 08:32 PM
u can get oem oversized pistons from oemacuraparts.com
Old Nov 3, 2010 | 11:14 AM
ivanson's Avatar
yea. i didnt realize to check acura.
but yea thanks
order thru acura.
pokie
11
Jun 20, 2010 07:23 PM
twigert
Apr 21, 2010 09:45 PM
Pandahatch
Feb 26, 2006 10:08 AM
1700anddroping
Dec 16, 2004 04:02 AM
SpeedDreamz.com
May 19, 2004 08:34 PM
