Question about ITR wing (need info ASAP!)
Old Sep 20, 2002 | 04:12 PM
PhatboyNYC's Avatar
Default Question about ITR wing (need info ASAP!)
Hey guys,
I have a 95 LS teg and I just bought an aftermarket ITR wing. I was wondering if you guys could tell me how much space there's supposed to be from the edge of the trunk to the rear base of the spoiler (? inches). Unfortunately, all 4 holes on the aftermarket wing (I know..what do I expect from getting an aftermarket wing) don't match up with the stock teg spoiler holes. I can either fit the two front screws or the two rear. I need to know how much space there's supposed to be from the edge of the trunk to the base of the spoiler to determine which holes I should be using and where to drill new ones. I'm planning on installing the spoiler tomorrow so if you guys could help me out, I'd really appreciate it. Thanks.
-Dave
Old Sep 20, 2002 | 06:08 PM
mugenracer's Avatar
Default Re: Question about ITR wing (PhAtBoY Si)
I had an ITR wing on my last teg, and if i remember right the base extended near enough to the edge of the trunk lid. If you use the back two bolts (the ones nearest the back of the trunk lid) where does that leave the edge of the spoiler base sitting? If its almost at the rear of the trunk lid, then i'd go with those two bolts and drill the front two in the postion needed for your spoilers bolt ends
ask or check thru the ITR section, theres bound to be pictures of ITR wings up close that should give you a fair idea where it should sit
[Modified by mugenracer, 3:09 AM 9/21/2002]
Old Sep 20, 2002 | 07:50 PM
PhatboyNYC's Avatar
Default Re: Question about ITR wing (mugenracer)
Well regardless of which holes I use, the base ends up near the edge of the trunk. I'm just not sure how close or far away it's supposed to be. If no one can take measurements for me, can you at least post close up pics so I can get an idea? Thanks in advance.
snowblind7x
Honda CR-V & Element
Nov 3, 2017 10:08 AM
Renegade
Aug 17, 2006 08:52 PM
Dc2 Powered
Sep 22, 2004 11:32 AM
PhatboyNYC
Sep 21, 2002 11:10 AM
