B16/EG/EJ1/Turbo Parts East Side San Jose
I'm parting out my honda civic 1995 EX EJ1, I had a JDM b16 engine in it that has oil leaks because of bad seals. Here's what I have, everything is OBO.
EG/EJ1 turbo charge piping -- $50
EG/EJ1 Intercooler, 3 feet by 1 1/2 feet, supports up to 26 psi of boost -- $50
EG/EJ1 Radiator with upper and lower hoses -- $50
GSR OBD1 distributor -- $100
B16A JDM head, needs broken bolts drilled out, just got resurfaced -- $250
Once used ARP head studs for B16, these are NOT TTY so they are good to be used again I'll even through in the 9/16th 12 point needed to get them in and out -- $100
P28 Chipped ECU for B16 NA or B16 Turbo -- $100
650CC Precision OBD1 B/D series fuel injectors -- $150
LS Transmission has slight grind when going into 5th at high speeds -- $100
LS Axles one is bran new from Kregen -- $100
P28 wiring harness used and works on both an OBD1 B16 and an OBD1 D16
2000 Si B16 throttle body with all working sensors -- $75
2000 Si Intake Manifold -- $50
B series (was used with the 2000 Si intake manifold) Fuel Rail -- $50
Toda 9.1 lb racing flywheel, has about 10,000 miles on it, retailed at $375, I will let the stage 1 excedy cluth and pressure plate go with it -- $250
Blox Fuel Pressure regulator -- $25
B16/B18/B20 4 bolt Stainless Steel Turbo header with stainless steel down pipe -- $150
B series Tapped oil pan for turbo -- $50
B16 short block, all seals need to be replaced but everything else is good -- $50
That's it, hit me up with your offer.
Hi,
Ok I have a few questions before I hit you with my offert..
1. Is the intercooler piping 3 inches? Is it the complete setup (clams, etc.)? will it fit a B16 on EG shassis?
2. What´s the part number on the ARP head studs? i need LS/Vtec.
3. Are the injectors new? lightly used?
4. Are you willing to ship to MIA zip 33166? Are they complete with seals ( O rings )
5. Would you take 275.00 for this 3 items?
6. Could you get all this in the smaller box you could find to ship?
7. Do you paypal?
If you do pls let me know so we could deal ASAP.
Rgds,
Oky
7. Do you paypal?
Rgds,
Oky
Hi,
7. Do you paypal?
Rgds,
Oky
7. Do you paypal?
Rgds,
Oky
hey i need that turbo header if u still have it. couple simple questions though. what kind of condition is it in, first of all. and 2nd of all what kind of material is it made out of? brand name? let me know asap (714) 702-5541
fekyoride
Apr 14, 2007 02:58 PM
