mpfi swap!! code 4 and code 16!!
Old Sep 20, 2002 | 03:58 PM
ahc'monracing's Avatar
Default mpfi swap!! code 4 and code 16!!
I just put in my 94 Ex intake manifold on my 90 Civic Dx and my ecu reads code 4 for the crank angle sensor and code 16 for the injectors.
Any assistance out there. My car starts up but it runs real sluggish because the idle is really low.
Desperate for some answers because it is driving me nuts!!!! Help!!!
Old Sep 20, 2002 | 04:03 PM
b16awarrior's Avatar
New User
Default Re: mpfi swap!! code 4 and code 16!! (ahc'monracing)
Are you still using your dx dizzy and ecu? If so there's one of your problems. Im currently trying to get my car started and I know how much of a bit#h this is
Old Sep 20, 2002 | 04:04 PM
altoid's Avatar
adjust the idle nut on the throttle? (quick fix for now?)
[Modified by altoid, 8:05 PM 9/20/2002]
Old Sep 20, 2002 | 04:07 PM
Default Re: mpfi swap!! code 4 and code 16!! (b16awarrior)
I'm running a Si dizzy but had to use the dx plug because I didn't have the Si plug in. So, I spliced the 5 wires to the dx plug in and left the 2 blue ones out for a straight splice to the ecu. Still, getting problems. Don't know what to do.
Old Sep 20, 2002 | 04:08 PM
New User
Default Re: mpfi swap!! code 4 and code 16!! (altoid)
Have you checked to see if you PGM-FI main relay is going out? I got that code for the fuel injectors month's ago and that what was wrong with mine.
Old Sep 20, 2002 | 04:10 PM
I got that changed maybe 2 months ago. Let me go try one more time to start my car.
Old Sep 20, 2002 | 04:13 PM
New User
Wait a minute, the the two wires, (blue/yellow and blue /green), aren't hooked up? Dude, that's your problem. Get those wired up.
Old Sep 20, 2002 | 04:17 PM
4gvtec's Avatar
b/y and b/g are not hooked up! well thats it man! they go to cps sensor.
C1: IS BLUE/GREEN
C2: IS BLUE/YELLOW
ON THE ECU
Old Sep 20, 2002 | 04:18 PM
they are hooked. they are running straight to the ecu. I just tried my car again and still the same. code 4 and code 16. I wonder if my dizzy's bad?
Old Sep 20, 2002 | 04:22 PM
4gvtec's Avatar
sure you have them wired right,not switched?
Old Sep 20, 2002 | 06:08 PM
New User
Default Re: mpfi swap!! code 4 and code 16!! (4gvtec)
I just got my car started, and that was my prob. Good luck with yours.
Old Sep 20, 2002 | 06:15 PM
Bongnak's Avatar
i had the same exact problem when i used my dx dizzy connector there are two white wires try switching them!
Old Sep 20, 2002 | 07:15 PM
Kasper.'s Avatar
try switching the b/g and b/y wires chance that the got switced around ......Injectors that could be from bad injector resistor box....bad ground wires on injectors.....lots of things......
low idle check your timing......ajust the t/p screw ......I did this whole shin-dig about 2 weeks ago...I still have lots of problems......mine with the vss, and somtims an electrical overload......
818blue818
29
Jul 14, 2009 10:48 PM
bgcrx
Feb 21, 2008 07:24 PM
pinoyboy204
Jun 8, 2005 07:32 AM
tysf
11
Jul 28, 2003 10:57 PM
Aphrodavid
Feb 25, 2002 02:42 PM
