Itr itb cams
Old Oct 27, 2010 | 11:34 PM
hood ride eg's Avatar
Icon3 Itr itb cams
Wanted to see what u guys think on the best cams to daily my itr with
current setup b4 tune & cams
is stock itr twm itbs hondata s300
really looking into blox b cams or blox hsl
these cams any good for my set upp??
Old Oct 28, 2010 | 05:43 AM
unusual71's Avatar
Default Re: Itr itb cams
use the cams that will help in the rev range you want the power in, whatever suits your driving taste.
itbs work well with aggressive cams, but without head work your going to be restricted by that. everything needs to work as a system, i would personally save up for headwork so you can match everything up with the itbs and whichever cam you decide to run. running a mild cam probably won't get you very much change i guess i would suggest the blox b between those two.
Old Oct 28, 2010 | 10:09 AM
Yeah Thats in the works too but gotta take it little by little lol
have u had expierence with the blox b's? I've heard the hsl r really agressive at high rpm not sure if that's true or not
Old Oct 28, 2010 | 10:18 AM
unusual71's Avatar
no personal experience sorry... what size are your itbs by the way?
Old Oct 28, 2010 | 10:45 AM
they r 52mm ill post a pic ina bit
Old Oct 28, 2010 | 01:30 PM
crappy phone pic
Old Oct 28, 2010 | 01:50 PM
2k.civic.si's Avatar
Jun 3 or toda B would probably be a kick *** cam for that setup unless you got the head ported out. If you get the head ported you can go with a lot larger cam.
Old Oct 28, 2010 | 02:51 PM
DDTECH's Avatar
i miss my itbs..
Old Oct 29, 2010 | 12:08 AM
Well aren't the blox b's almost alike as the skunk 2 stage 2? Na I don't have a ported head yett .
Any1 think the hsl cams r good for the setupp ? Another option was to wait for skunk2's swapmeet event they r having ..
Old Oct 29, 2010 | 10:21 AM
DDTECH's Avatar
skunk2s tuner2's are a junIII copys..
first off all tuner series primary lobes are stockish.. and when vtec kicks on ya, it kicked in y0.. the pro series was design to get rid of this feeling
if your going to use a cam. Use a pro series, or a custom grind of some sort.
Old Oct 29, 2010 | 01:01 PM
yeahh thats what iam trying to avoid some " stockishh aftermarket cams " i want some Agressive cams that will make power , since my goal is 220-230whp tops.. also picking up supertech valvetrain..p&p head along the way...etc
but yeah haha " when vtec kicks on ya, it kicked in y0 "
Old Oct 29, 2010 | 03:07 PM
Frankacura's Avatar
Your Stock R cams are good (daily driven)
My B20Vtec did run 109mph in my 2550 pounds integra.
But i love the TODA B X2
The cams that bring the biggest torque, and RELIABLE...
Old Oct 30, 2010 | 12:52 AM
^ lol today is for dee balllas! :O
5ton
Engine Management and Tuning
May 3, 2015 07:46 AM
JPerkMr954
Apr 5, 2011 07:13 AM
Easyslider01
Oct 7, 2006 04:23 PM
95vtec
Sep 30, 2001 11:13 AM
Rhetoric
Sep 10, 2001 07:52 AM
