nippon p73 pistons
Well after reading a lot of good stuff about the nippon pistons i decided to order a set for my rebuild on my type r motor. I ordered a set on ebay which said jdm itr p73 pistons. I recieved the pistons and they say p73-a0. I thought p73-a0 was usdm type r pistons with 10.6 compression and p73-00 was jdm itr pistons with 11.1 compression. So my questions is does nippon make a copy of the usdm and also the jdm ones or are they just labeled a0 but will still have 11.1 compression?
Im pretty sure the only way to get the JDM P73-00 pistons is through a dealer, or a supplier who imports them. I have never seen a "aftermarket" remake of them.
Can you supply a pic of the dome? Im pretty sure they would not stamp them 1 thing when they were another.
p73-A0 (USDM B18C5)
p73-00 (JDM B18C5)
I know you can get OEM USDM and JDM pistons from RS machine. You can get them oversized to. Here is a good Honda compression calculator.
http://www.c-speedracing.com/howto/c...c/compcalc.php
p73-00 (JDM B18C5)
p73-A0 (USDM B18C5)
p73-00 (JDM B18C5)
p73-00 (JDM B18C5)
The Nippon ones are USDM copies, not JDM. I looked at them when I was buying ITR pistons.... and 93eg is correct, it's impossible to find JDM ITR .25 OS pistons now.
i asked the seller and this is what he told me:
These are copy of the higher compression pistons. The dome height is just like the JDM ones. The deck is stamped AO because the USD have deeper valve reliefs so they can be used with High Lift camshafts.
I call BS on that one.
stonet149
12
Nov 2, 2008 09:29 PM
InfamousRS
Sep 21, 2002 05:59 PM
