Electronics and Fuel management( Hondata, Injectors, FPR) for Toda,JDM ITR,B18C rebuild
Old Sep 20, 2002 | 03:19 PM
Spyderwebab's Avatar
Default Electronics and Fuel management( Hondata, Injectors, FPR) for Toda,JDM ITR,B18C rebuild
I'm rebuilding my B18C after its hydrolock, I need recommendations on Electronic and fuel management. I'm was running with the VAFC and stock Injectors and stock FPR, but I think its time for an upgrade!
I've had recommendations for both the JDM ITR and the CTR Pistons to use with my Toda B's, but since this is my daily driver and I don't race THAT often I'm going with the JDM ITR Pistons and ITR rods, I decided that 11.5:1 CR is good enough. I'm also doing a slight valve angle job when I install my new ITR valves.
The point of the post is basically should I go w/ the new Hondata s200 or stay w/ my VAFC?(Whats the difference between the new s200 and the stage 2/3/4?) Has Anyone had long enough time to become familiar with the system? Is it Pretty much the same as the 2/3/4? Its not very expensive only $295 and I think it would be a good upgrade.
Mike M. recommended the AEM FPR and the 440cc with the hondata, but that was for the CTR(~12.2:1 CR) Do I need to go w/ that large of injectors for the JDM ITR pistons?
Anyone w/ a similar setup please post your dyno #'s. (A b18c5 w/ same mods is similar enough for me.) Also the intake and exhaust mods are in the sig.
Old Sep 20, 2002 | 03:21 PM
Big Phat R's Avatar
Default Re: Electronics and Fuel management( Hondata, Injectors, FPR) for Toda,JDM ITR,B18C rebuild (Spyderw
Go with the Stage 2 Hondata - you will have much better throttle response.
Old Sep 20, 2002 | 09:11 PM
rainmanEK's Avatar
big strong guy
im having same problem deciding, any one else? eric
Old Sep 21, 2002 | 02:52 AM
sgT's Avatar
sgT
JDM ITR Pistons are 11.1:1 CR. If you want 11.5 you should use 99 civic si pistons.
You dont need the aem fpr with the hondata.
i will have the new s200 next week. I'll know all about it then.
Old Sep 21, 2002 | 09:16 AM
11.1CR in an ITR maybe, but its a b18c1, sorry I didn't state it was a GSR motor, w/ a 2 layer headgaket it should have ~11.5 CR. So you think I should ditch the VAFC for the Hondata? Since you suggest that I wouldn't need the FPR I guess I wouldn't need the injectors or would I?....
Anyone Else want to help out?
Old Sep 21, 2002 | 09:23 AM
BlueR's Avatar
you will still need the injectors...not the fpr
Old Sep 21, 2002 | 09:25 AM
Now is that if I DO go with the Hondata?
What size the 310cc or 440cc w/out the FPR?
Old Sep 21, 2002 | 09:27 AM
BlueR's Avatar
yes...even with hondata you will still need/should use bigger injectors...
prolly 310s...at most 370s
b20vtech
Mar 9, 2006 06:24 PM
Nice_Dc2r
19
Feb 24, 2004 05:34 AM
danny98r
Feb 12, 2004 07:53 AM
kuya kanin
Oct 2, 2002 06:28 PM
gsr98vtec
Dec 19, 2001 06:41 AM
