fs: ls vtec complete swap
98 b18b1 bottom end
99 gsr head redone by dover cylinder head
01 gsr trans
golden eagle ls-v kit
arp headstuds
new headgasket
new clutch
new pilot bearing
new throwout bearing
new slave cylinder
new water pump
new timing belt
new spark plugs
new spark plug wires
new intake manifold gasket
itr red valve cover
itr throttle cable
itr throttle bracket
jg edelbrock victor x manifold
bdl 70mm throttlebody
99-00 si engine harness
99-00 si t bracket
99-00 si shift linkage
99-00 si axles pair
01 gsr ecu obd2b
dc sports 4-1 headers
everything needed to swap and motor guaranteed under 9k miles... motor was babied and never tooken over 7k rpm.. please email me at slow.ek.hb@gmail.com or text me 904-859-8733
01 gsr trans
arp headstuds
new headgasket
new clutch
new pilot bearing
new slave cylinder
new water pump
new timing belt
new spark plugs
itr red valve cover
itr throttle cable
99-00 si t bracket
99-00 si axles pair
01 gsr ecu obd2b
