Putting a Block back together?
Old Sep 20, 2002 | 03:12 PM
stayontrack's Avatar
Default Putting a Block back together?
What are all the tools I will need to put a block together....i got this free and is bare and i am goin to LEARN how on this block(so dont flame me for trying to put a block togeter but i dont even know wat tools to use) Thankyou
Old Sep 20, 2002 | 05:29 PM
lazy bum shaughn's Avatar
Default Re: Putting a Block back together? (Joe_21)
Invest into a Helms manual.
Old Sep 20, 2002 | 06:00 PM
b19coupe's Avatar
Take your time and do it right. Invest in a torque wrench. Buy some plastiguage from your local parts store and plastiguage your bearings. And (as stated above) get a Helms or similar manual.
Old Sep 20, 2002 | 06:21 PM
Default Re: Putting a Block back together? (b19coupe)
Can i buy a Helms manual at a store or it has to be bought online?
Old Sep 20, 2002 | 06:57 PM
b19coupe's Avatar
Check your local autoparts stores-some carry Helms, Chilton's, etc.
Old Sep 20, 2002 | 07:35 PM
3rdGteg's Avatar
The only other place besides online I've seen is at the dealer, but they're a little bit more. Helm's IS the one you should get if any though. Good luck.
Old Sep 21, 2002 | 02:44 AM
Westrock2000's Avatar
Default Re: Putting a Block back together? (3rdGteg)
yup helms, 3 times as much as a haynes, but about 50 times more informing. You'll need a 10mm, 12mm, 14mm ratchet/wrench a torque wrench, needs to go up 90 Lbs at least (its good to get two, so you have a small one thats say 5 - 30 ft-lbs and then another that does like 25-150. If its in descent shape and not too beat up, you can keep the bearings, but should you take off that crank, you'll want to get new bearings for that.
http://www.helminc.com
[Modified by Westrock2000, 5:45 AM 9/21/2002]
accord-euro-r
Oct 22, 2015 09:08 PM
mtnatom
K Series
Jan 16, 2013 11:18 AM
RomeOWN
Apr 2, 2012 07:40 PM
(puma)
Sep 12, 2005 08:24 PM
GZERO
Oct 16, 2002 06:52 AM
