98 accord 5spd, 'redlines' at 4k RPM
Old Oct 27, 2010 | 08:36 AM
krizzeam's Avatar
Default 98 accord 5spd, 'redlines' at 4k RPM
check engine light came on and now when i rev engine it stops accelerating at 4k RPM, like it would if u rev'd up to redline.
isnt 4k RPM when vtech kicks in? seems like the problem maybe related? idk.
it also seems to have started bogging down when idle when i let off accelerator it drops down to under 500rpm for a few seconds bfore jumping back up to the normal 800-1000 range.
any ideas here?
Old Oct 27, 2010 | 05:14 PM
poorman212's Avatar
Default Re: 98 accord 5spd, 'redlines' at 4k RPM
Ok, what are the codes? The car is in limp mode....not much to do until the issue is solved/fixed/identified.
Old Oct 27, 2010 | 06:08 PM
marquisdee1018's Avatar
It could be a number of things but my showed the same symptoms when my vtec solenoid went out.
Old Oct 27, 2010 | 09:10 PM
holmesnmanny's Avatar
What were you doing to the car in the days prior to the check engine light coming on?
Old Oct 28, 2010 | 08:30 AM
krizzeam's Avatar
I havent done any work on the car recently.
the code was 12xx (fuel air something something)
tcavazos
Jul 16, 2013 07:22 AM
mr0lg
Jul 28, 2011 04:54 PM
rocket1356
Feb 25, 2008 04:33 PM
fineAccord
Feb 25, 2006 12:06 PM
Si12iuS
Dec 27, 2005 03:53 PM
