BFG g-force owners, have a couple of questions
Old Sep 20, 2002 | 02:44 PM
lilcasino's Avatar
Default BFG g-force owners, have a couple of questions
I just got some 14" BFG G-Force radials for my 98 integra gsr. I have never used drag radials before and have no idea how to launch these. This is my current setup:
AEM CAI
JDM Header/carsound cat/Apex N1
Comptech Alum. FW/ACT HDSS
My reason for getting these tires is that when I launch I have tons of traction problems, mainly because my car revs so easily with the 6.75 fw. I have had a couple of people drive my car and they get the same result.
Old Sep 20, 2002 | 02:57 PM
Austin's Avatar
Default Re: BFG g-force owners, have a couple of questions (lilcasino)
I had the 205-50/15 tires at 10 psi, and was launching at 6000rpm...but I have a little more power.
Austin
Old Sep 21, 2002 | 01:08 PM
b18b98's Avatar
AEM CAI
they come in 14"s now??? Where did you pick yours up?
Old Sep 21, 2002 | 01:17 PM
Incognito's Avatar
Default Re: BFG g-force owners, have a couple of questions (b18b98)
Drop pressure to 12 to 15psi, do a good burnout (NOT in the water), launch at 7000rpms and don't look back.
Old Sep 21, 2002 | 03:35 PM
lilcasino's Avatar
got them at tirerack.com 205-50-14's 99$ each
Old Sep 22, 2002 | 10:16 AM
mannyman's Avatar
El Veterano de Sur Califas
Default Re: BFG g-force owners, have a couple of questions (Incognito)
So you go around the water box, pull up the ebrake and do a burn out??? And are they that great that they will hook up when u launch at 7k rpm?? thanx, I just might have to get me some of these.
manny
Old Sep 23, 2002 | 02:20 AM
Mista Bone's Avatar
D Tranny Guru
Default Re: BFG g-force owners, have a couple of questions (mannyman)
I doubt they will hold a 7000 rpm launch, but shouldn't spin very bad.
Remember SOME slippage is GOOD!!!! Rubber grips the best when it is just barely sliding. The amount of slippage depends on the compound.
Old Sep 24, 2002 | 07:42 AM
SergEK's Avatar
Default Re: BFG g-force owners, have a couple of questions (Mista Bone)
A dry peel is better for these tires. I pull around the water box and back up just before the fronts hit the box and dry peel to the line without setting the beams off. I cut a 2.08 60 the other day with them so they can hook I lauched at 5-5.5K with a balance between grip and slip. This was at 17 psi so I may try a little lower but I think its killing my top end the lower psi I go as I used to gain about 20 mph on the back end now its like 18-19 mph on the back side.
Still for the money the #1 mod I made to my car for the strip.......times DROPPED big time. You will love them.....and your car will launch much harder than on regular streets.
Remember to heat cycle before using them and try not to use them on the street for daily duty.....max they would last 6K miles anyway so I would keep it for the track.
Old Sep 24, 2002 | 11:54 AM
mannyman's Avatar
Default Re: BFG g-force owners, have a couple of questions (SergEK)
can u explain heat cycle??? thanx
Old Sep 24, 2002 | 01:28 PM
Mista Bone's Avatar
D Tranny Guru
http://www.tirerack.com/tires/tirete...tcycletech.htm
Kings Performance
Feb 1, 2007 06:25 AM
reallycooleg
Apr 20, 2006 08:56 PM
pete332
Oct 11, 2004 06:56 AM
Buckshot
Jan 6, 2003 05:31 PM
MintyDip
Aug 15, 2001 10:03 AM
