Need the experts help! What will i need? include EVERYTHING
Old Oct 26, 2010 | 04:49 PM
Beasty91Hatchy's Avatar
Default Need the experts help! What will i need? include EVERYTHING
i have a d16z6 with a L3 trans in my 1991 civic hatchback
sohc vtec ..
i want dohc vtec, but dont wanna do a huuuge job, so will a mini-me setup be the best bet?
what will i need? list everything and ill gib you a gold dollar !
can i do 1.8 dohc vtec head on my d16z6 block?
Old Oct 26, 2010 | 04:53 PM
DR.P3PP3R's Avatar
Default Re: Need the experts help! What will i need? include EVERYTHING
lol sorry bro but u cant
Old Oct 26, 2010 | 04:57 PM
NOOOOOOOOOOOOO
not the answer i wass hoping for, thanks for the bad news !
lol
my car is fast enough right now, i was just hoping for a dohc ..
can i do a 1.6 dohc head on my 1.6 sohc block?
Old Oct 26, 2010 | 05:02 PM
90civicstdgold's Avatar
D16z6= single cam
You CANNOT put a B series head on a D series
If you really want a dohc, go buy yourself a dohc zc.
Its pretty much a direct swap and youll have your dohc.
Old Oct 26, 2010 | 05:06 PM
Originally Posted by 90civicstdgold
D16z6= single cam
thanks.
ill do that when im ready .. for now, ima b rockin this d16z6 lol.
its a beast though (for what it is anyway)
ima post a thread with pics and **** in a few minutes, haters feel free to hate please.
Old Oct 26, 2010 | 05:08 PM
D16SiHatch's Avatar
i'm aware of 1 person who did it and it was a **** ton of work. not worth the effort when you could put that same energy/money into an actual dohc engine.
Old Oct 26, 2010 | 05:13 PM
Nothing wrong with single cams. Everybody seems to hate them though.
Old Oct 26, 2010 | 05:39 PM
pimpwagon's Avatar
sohc vtec ..
Noone else seemed to catch this so i figured i'd point out: if you have a z6, you already have a vtec motor. the only reason to build a mini me is to put a vtec head on a non vtec d15/16 block. you already have a mini me...
which fuel injection are you running? was it an si to begin with? was it a dx with dpfi?
and yes, like D16sihatch said, you can put a dohc zc head on your block but its pointless and alot of work. 1 head bolt becomes an issue and the oil ports are shifted over too. not worth it, but can be done.
Old Oct 26, 2010 | 05:43 PM
im new to the swap scene but not honda scene
anyways, i was hoping there was a different kind of mini me setup like 1.8dohc head with a z6 block, but like you and everyone else said, its not worth the work and/or its not possible.
so, im going to stick with the z6 until i can figure out what it will take for a full 1.8 dohc swap. or even a 2.0 if its possible without a ton of work
Old Oct 26, 2010 | 06:18 PM
pimpwagon's Avatar
well if you want the b swap, d16sihatch put some nice work in to help ease the pain.
https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/detailed-b-series-into-crx-ef-civic-parts-list-more-2769325/
this will get you most of the way through, if not all.
that z6 aint a bad mill. a little short on torque, but rev happy, and efficient. you could swap your cam, full exhaust, some cold air, and a tune and be close to ls territory without too much money or work.
Old Oct 26, 2010 | 06:29 PM
ExtraBlackRex's Avatar
I don't think it's hate, but recognition of the advantages of DOHC over SOHC when building for power are to obvious to ignore, from a tuning stand point in itself, the DOHC would be the optimal choice, especially if you're going all-motor. You really can't make power (ALOT of it) in a D Series (or even a B series in some cases) without using boost, so when you get to bang-for-buck the dually comes out. If you threw $400 into a SOHC if your upgrades don't invovle BOOST then you won't see the numbers you'd make if you spent that 400 on a dually, a bone stock LS Swap can be obtain for just a tad bit over 400 actually and the performance difference over a z6 is VERY significant.
Old Oct 26, 2010 | 07:29 PM
pimpwagon's Avatar
maybe someone could clear something up for me. if i have a sohc 16 valve motor and a dohc 16 valve motor, why does it make more power automatically? if the lift is the same profile for a single cam then split up onto two cams, wouldnt that be the same? the valve train would weigh close to the same(they both are 16 valve motors). there is less rotating mass in the sohc valvetrain (only one cam) what am i missing?
phoQ
22
Nov 11, 2021 07:59 PM
deeloo
Jun 15, 2016 08:23 AM
screen_name
Feb 1, 2006 07:59 AM
Irish Integra
Mar 9, 2005 09:56 AM
BOSS-REX
Nov 13, 2004 03:39 PM
