NC 91 dx hatch sale test
MAKE OFFER
91 dx phantom grey hatch
ls-v turbo
340hp 255 tq @ 12 psi
BLOCK
gsr crank
wiseco 9.8:1 piston
eagle rods
block guard
type r water pump,oil pump
stage 4 competition clutch
light flywheel
a1 trans open diff
HEAD
ferrea valve,springs,retainers
aem cam gears
gsr cams
msd distributor,blaster coil
vc breather kit z-10 catch can
skunk 2 intake mani
TURBO
precision 6061s
precision 46mm WG
precision 600hp IC
inline pro T3/T4 cast mani
3" ss dp with 3" 1/2 back exhaust
hks bov
MISC
precision 650cc injectors
255lb walbro fuel pump
obd 1 jumper with p28
d680 battery
innovative crossmember
misimoto 1/2 2 core radiator
hasport mounts and linkages
skunk 2 coilovers
tokiko 5 way shocks
front camber kit
slotted rotors and ebc green pads
autometer phantom boost,water temp,oil pressure
ls-v turbo
BLOCK
gsr crank
wiseco 9.8:1 piston
eagle rods
block guard
light flywheel
a1 trans open diff
HEAD
aem cam gears
gsr cams
skunk 2 intake mani
TURBO
precision 6061s
precision 46mm WG
precision 600hp IC
hks bov
MISC
d680 battery
skunk 2 coilovers
tokiko 5 way shocks
front camber kit
V12EATER
Oct 12, 2005 08:49 PM
91civicDXdude
32
Mar 23, 2004 03:10 PM
