Suspension & Brakes Theory, alignment, spring rates....
koni/ ground control combo
Old Oct 25, 2010 | 11:12 PM
Luca's Avatar
Default koni/ ground control combo
i brought my car with ground control sleeves on my stock shocks, and found a good pair of used koni yellows. i'm just curious it would just fit right in if i wanted to drop the gc sleeves into the konis? or whatever part that is needed for it.
Old Oct 27, 2010 | 02:09 AM
Luca's Avatar
Default Re: koni/ ground control combo
/bump
Old Oct 27, 2010 | 06:10 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
No they will not fit. You need GC sleeves made specifically to fit Koni shocks.
Old Oct 27, 2010 | 11:29 AM
Luca's Avatar
ok thanks, guess i'll get swift springs
Old Oct 27, 2010 | 06:11 PM
98civdx's Avatar
Master Detailer
Try conntacting koni, you may be able to buy adapters
Old Oct 28, 2010 | 06:31 AM
96hb's Avatar
You can get the Koni specific sleeves from Ground Control for like $120. That's what I had to do earlier this year when I upgraded to Koni shocks.
Old Nov 1, 2010 | 08:17 PM
XtremeCarTuner's Avatar
If you are going to do all that, might as well finish it the right way and buy the top hats.
Old Nov 2, 2010 | 04:12 PM
Community Builder
Not needed if the car isn't super slammed or if the springs are stiff enough. They make the UCA's much more likely to contact the shock towers anyway.
Iloveyourhonda92
Suspension & Brakes
Dec 29, 2010 10:24 PM
dxlol
Suspension & Brakes
Oct 21, 2010 02:09 PM
PatrickGSR94
Suspension & Brakes
Mar 25, 2010 04:37 AM
BoosterSH
Oct 13, 2003 09:34 AM
