Helpful Video
This is part 1. Just a little guide on how to remove subframe and transmission. Nothing fancy and nothing great. Just thought I would try it out. Tomorrow I'm pulling the engine and will probably make a part 2.
http://www.youtube.com/watch?v=6oIssf4El5w
Part 2 (removing supercharger and engine)
http://www.youtube.com/watch?v=U_fRMhljlxk
Part 3 (swapping and cleaning parts)
http://www.youtube.com/watch?v=Ede9u99KToo
Part 4 (How to instal clutch and flywheel)
http://www.youtube.com/watch?v=rRbms5iiMqM
Part 5 (Installing engine and transmission)
http://www.youtube.com/watch?v=cPQImsbD30E
Part 6 I put my supercharger back on
http://www.youtube.com/watch?v=90U6Me8VLRo
Part 7 Installing the subframe on your own
http://www.youtube.com/watch?v=bQj-qhsb2Yg
Part 8 sway bar, header and Valve Cover instal
http://www.youtube.com/watch?v=-oUjrCTnnUo
Part 9 fluids
http://www.youtube.com/watch?v=qo1SxPNG53g
Part 9 fluids
You can't change the flywheel without removing the transmission.
I can get the transmission out from start to finish in around 30-40 minutes. Getting the trans out isn't a big deal. Getting it back in alone thats a different story... lol
Yeah I didn't know if you could get enough gap between the two to work. I guess that doesn't make sense though. Is it, remove the subframe then drop the tranny and then do the work? Is that about right minus the axles and little things?
yup pretty much. Just drop the subframe. Then pull the trans. And a lot of little misc things in between. But I've done it sooo many times I think I could seriously do it in my sleep.... takes about 30mins start to finish to get the tranny out. (for me)
