Finally Completed! The Nitrous Injected Crx
A few people have been asking the status on my crx. Well I can finally say it is completed! I will be attaching a bunch of photos of the car I took today. I am very happy with the way it turned out. I look forward to putting down some very good track times. Timeslips and vids will be posted in the future.
Thanks for the kind words guys. I will get into more detail on the setup later when I have more time. But briefly, everything motor-wise is setup for a big shot of nitrous 150 up to 250. It is a b16a darton sleeved with an 84mm bore. compression around 10.5-1 w/ flat top pistons. 1mm oversized exhaust valves and ctr exhaust cam. P&P head. I have a seperate fuel system dedicated to the nitrous system with its own adjustable regulator. Clutch is an exedy twin, axles and hubs are dss stage 5, custom traction bar with front motor mount. Nitrous system is a 1 off nitrous express direct port 2 stage wet setup. Exhaust uses a qtp electric cutout for quiet street action and wide open track use. 8.5/24.5-13 m&h slicks w/ Diamond racing wheels. The car is still very much streetable and has a full interior. My current goal is 11.50 in full street trim w/ slicks. I race at heartland park Topeka, Kansas so you will have a long drive to come see it in action.
wow first time ive seen a setup like that on a honda, nice. that being said i cant believe nobody has said something like this yet............... all that money into that sweet *** setup and u have a dc header on it???
mike
mike
set-up looks great just not a fan of those distribution blocks horrible in my opinion. I cant wait to see some vids of it in action though. what kinda or ems u using aem or s300 etc...?
Also, I'm in Kansas for school so I'm pretty close to you. I'd love to see this car in action.
That is the only thing I would change on his kits. I would have went with NX showerheads, but it will definitely get the job done.
I am using a microedge controller. If I wanted. I could use 3 stages with 2 kits. just for example with 50 jets in one stage and 100 jets in the other. I can launch on 50 then switch to the 100 then bring back in the 50 for a 150 total.
Sounds like a nice setup. I like how you did a separate fuel system for the nitrous kits. That is the way to do it!
Those distribution blocks aren't horrible, but they won't be exactly even as well.
Your welcome to post the WON vid of the distribution block test if you would like. It wont hold up under PRESSURE.
Hope to see you at the track in the future!
Thanks, Its defanitly over the top. On the dc header I guess I am no header expert and its wide open with the cutout anyways so it should work well for me.
Great setup!
However I am agreeing the header you have will be the restrictive point especially with the big shot... a custom header would be best in power and on the track...
