Re Drilling Oil Pressure Sensor, How to remove shavings?
Hi guys my b18c block is at the best engineer in my area getting the oil pressure sensor location re drilled and tapped. The engine has only done 30,000 kms so im not too keen on stripping it. Is there any way for me to flush these shavings out?? (not that there would be much)
thanks, bump holes drilled and tapped. Would cranking it without the oil pressure sensor in work? Would spit out oil and hopfuly the shavings?
Didnt Re Locate, when putting the sensor into the block it cracked around where the sensor goes. Iv got the block back he didnt drill just needed to re tap after welding. But still there will be a small amount of metal shavings.
i know this is a dead thread but a way to get the shavings or at least most of the shavings out would be to start the motor with the switch out and let engine oil spray out, taking most metal shavings with it.
Charlie Moua
Mar 10, 2010 02:36 PM
Playa_FL
Mar 21, 2007 06:47 PM
