Codes on my swap
Alright so I swapped a 96 spec b18c in my ef sedan. It runs strong but then it has an intermittent problem where it bogs hardcore under any throttle. It throws a code and it is 4,7, and 17. TPS, CKK, and VSS. Now when I did this swap I had it wired to boomslang's diagram but they had the CKK and CYY sensors mixed up on their diagram. It took my awhile to track that problem down but now it is doing this bogging crap. Dizzy is new but could I have nuked it trying to start it with those sensors connected backwards? I also have checked the TPS like twelve times and I think it might be bad but just wanted to try and get some other views before I start throwing parts at this thing. The voltage can be set for 0.5v and then when it starts ****ing up I checked it again and the voltage will have jumped up to like 0.54 or 0.55. Any help or insight will be appreciated. Also with that code 17, the VSS I dont have any speedo hooked up because well, hydro tranny and I don't have the electronic speedo sensor. Alright thanks in advance.
