1990 honda civic si hb legal motor swaps?
Old Oct 25, 2010 | 12:58 PM
dwils's Avatar
Default 1990 honda civic si hb legal motor swaps?
what kinda of motor can you swap in a 1990 honda civic si but also do it with a legal bar swap
Old Oct 25, 2010 | 01:01 PM
singlecamsaint's Avatar
Default Re: 1990 honda civic si hb legal motor swaps?
well im not from cali or anything but im sure you can swap in anything thats a direct replacement (like d16a6 to sohc zc), but from the threads ive seen here, it appears you can put anything in it that isnt a light truck motor like the B20, but idk someone from his area help him out
Old Oct 25, 2010 | 01:05 PM
dwils's Avatar
cali sucks i was looking into doing a b16a swap in it than i called the state ref and they said no sooo im kinda stuck now
Old Oct 25, 2010 | 01:07 PM
someone will post that knows for sure, im 3000 miles away where smog laws dont really exist like they do there, if anything earch because i have seen a thread on this somewhere
Old Oct 25, 2010 | 02:08 PM
24TEN's Avatar
PHANTOM MENACE
As far as I know, same rules that have always applied still hold true for US motors. It has to be the same year as the car or newer, you have to have the correct smog equipment for that motor, and you cannot use truck motors (specifically for our case B20 cannot be used). Factor in JDM motors, you can only use them as direct replacements meaning if you're car came equipped with say a B16A2/3 then you can use any B16A as a replacement so long as you retain the correct smog equipment. If you're car never had the option for the JDM motor you want to put in it then you can't use it.
I know there was a thread not too long ago (after the JDM swap laws changed) that someone here in California did in fact use a JDM GSR in a Civic and the referee said it was fine. Bottom line though, if you have ANY questions you really should get in contact with your local referee. They actually are there to help you.
Old Oct 25, 2010 | 07:42 PM
dwils's Avatar
sooo i can't put a jdm motor in my car because it didnt come with one correct?
Old Oct 25, 2010 | 08:05 PM
BiG ChOr!Zo's Avatar
http://www.arb.ca.gov/msprog/aftermkt/replace.htm
Old Oct 25, 2010 | 08:30 PM
dwils's Avatar
is it legal to turbo it?
Old Oct 26, 2010 | 05:25 AM
88EF4dr's Avatar
I had a DOHC ZC in my 88 smogged fine never questioned me and my stock motor was SHOC 1.5...
Old Oct 26, 2010 | 08:00 AM
Ludster's Avatar
An ignorant smog station doesn't qualify as being legal. A dohc ZC will never be smog legal in the US. That motor was never offered here or anything equivalent.
If you bring your car to a REF for just a routine smog check, he will give you the finger.
Old Oct 26, 2010 | 10:07 AM
maybe in cali but not here tons of folks here have sohc and dohc zc's in there ef's, not to mention all the other swaps that have been done here
Old Oct 26, 2010 | 10:14 AM
Ludster's Avatar
Yea, I forgot to mention in CA. But you don't worry about legality of swaps in other states like CA, so it should be a given where the OP is.
Old Oct 26, 2010 | 10:16 AM
im guessing the op lives in cali but he didnt really tell the world so idk he just asked what was legal and what wasnt lol im pretty sure in the state of GA, if you can get that baby in there its legal
Old Oct 26, 2010 | 11:05 AM
javie3's Avatar
ARE B18C1 or c5 motors LEGAL FOR THE EF'S
Old Oct 26, 2010 | 11:10 AM
Ludster's Avatar
Of course.
Make sure the VIN is on the motor and you have proof of a legal sale if the REF asks.
You will need all of the emission components to match the vehicle the motor came out of. Evap controls, o2 sensors etc.
Also if the motor came out of and OBD1 car, you need to convert to OBD1. Same goes with OBD2
Again the above is for CA.
Old Oct 26, 2010 | 12:50 PM
Originally Posted by Ludster
A sohc/dohc ZC will never be smog legal in the US. That motor was never offered here or anything equivalent.
the zc sohc is legal but the zc dohc isn't...although the zc dohc could be considered equivalent to a 88-89 integra motor in some aspects...!!!
Old Oct 26, 2010 | 12:54 PM
Ludster's Avatar
I just remembered that you can smog a sohc. Thanks for the correction.
I've never seen a dohc zc legally smogged though.
Old Oct 26, 2010 | 12:57 PM
if i moved to an area that required smog checks how would i go about passing it with a b series. if i read correctly i would just need the smog equipment from the integra right?
Old Oct 26, 2010 | 01:04 PM
i've smogged a zc dohc at a regular smog check before...that was at one of your basic smog check spots in south central los angeles where they dont care or dont know the differences in motors.
i did however literally give the finger to the ref at east la college a few years back because he didn't want to perform a db exhaust test on my old sedan since it was swapped with a zc dohc motor with a ricer fart can.
i just drove away over to the chp and got the ticket signed off for free and paid the $10 correction fine
Old Oct 26, 2010 | 01:06 PM
Ludster's Avatar
Depends on the state. CA, then yes.
Old Oct 26, 2010 | 01:11 PM
ok well GA smog laws are retarded where i live in my state there are none, but closer into atlanta there are smog stations everywhere thats why i asked
Old Oct 27, 2010 | 02:46 AM
88EF4dr's Avatar
Thats what I thought but I didn't only take it to the same place every time it needed a smog, also took it to Test Only places.. I guess I was just lucky then. I now have a SOHC ZC in it and it passes smog good no prob. since I thrashed the DOHC ZC...
Old Oct 27, 2010 | 11:34 AM
jdm-turtle's Avatar
Icon2 Re: 1990 honda civic si hb legal motor swaps?
im in cali and they told me if your car didnt come with vtec you cant swap in a motor with vtec for smog reasons... who knows if this is true... im currently debating between a zc sohc or z6 witch i heard were the best usdm and jdm sohc motors... can someone verify this.. please...
Old Oct 27, 2010 | 11:38 AM
jdm-turtle's Avatar
currently have a 89 civic sedan with a lsvtec and need to swap out motor for the ref...sigh looking for a decent motor that will pass smog and keep me happy for my dd. again located in cali....
Old Oct 27, 2010 | 11:39 AM
jdm-turtle's Avatar
pump.. i wanna know as well.
