HELP W/ 88 CIVIC
Old Oct 25, 2010 | 12:00 PM
TAZNGOOFY's Avatar
Default HELP W/ 88 CIVIC
MY SON BOUGHT AN 88 CIVIC, IT RAN WHEN WE PURCHASED IT, HAD A BIT OF A MISS TO IT. DIED ON WAY HOME, FOUND SOME WIRES TOUCHING, HAD REWIRED, THEN RAN FINE, PUT NEW DISTRIBUTOR , VALVE COVER GASKET , SPARK PLUG WIRES AND PLUGS, RAN FINE , NOW HAS PROBLEM. WILL START BUT ONCE WARMS UP BOGS AND SPUTTERS, ONCE GIVEN GAS IT DIES, ALSO BLOWING WHITE/ BLUISH SMOKE, I THINK HE DROVE IT LIKE HE STOLE IT AND BURNED RINGS, WHATS YOUR ADVISE
Old Oct 25, 2010 | 12:25 PM
singlecamsaint's Avatar
Default Re: HELP W/ 88 CIVIC
honestly im thinking head gasket, white smoke is coolant usually, check compression. is the oil milky, is there oil in the coolant, try all this first
Old Oct 28, 2010 | 07:13 PM
HWKR3W's Avatar
hmmm as far as it bogging out whn yu hit the gas try buying sum fuel filter cleaner. or check your fuel pump. it sounds like a fuel delivery problem.
KlippMike
11
Nov 7, 2018 02:48 PM
hulsey
16
Mar 19, 2012 12:00 PM
superspadez
Jul 27, 2011 09:39 AM
Mini Prime
Nov 27, 2004 05:36 PM
Verdegsr
Nov 11, 2003 09:50 AM
