Mid-Atlantic (Sales) VA, DC, and MD
1999 Acura Integra GSR Part-out (Tan Int. Cypress Green Ext.)
Old Oct 25, 2010 | 11:50 AM
B16Civic93's Avatar
Default 1999 Acura Integra GSR Part-out (Tan Int. Cypress Green Ext.)
For sale
1999 Acura Integra GSR Interior and body parts
Interior:
Dashboard with harness $120
Both Airbags and SRS unit and Harness $120
Center Console Front Half Only - $35
Steering Wheel - $50
A-Pillars $20
B-Pillars $20
Trunk Plastics $25
Glove Box $45
Steering Column Plastics $30
Dome Light $10
Map Light $10
Clock $15
Exterior: (Cypress Green)
Front Core Support(including Front half of inner fenders) $100
Front Bumper support $30
Rear Bumper Support $30
Rear Bumper Older style Flat Bottom (Missing some paint, no deep scratches, holes etc...) $45
Harness UNCUT
Body harnesses that go inside along the floor on both sides of the seats, goes to the back across where the taillights are and the one that goes up into the hatch to feed the rear wiper and defroster. also have defroster ground wire $80
Under the hood:
1994 Acura Integra GSR Swap 100% complete.
Engine was pulled from a running car, saw and heard it run, didnt smoke, tap, knock, overheat. Did a compression test and it was within 6% of 220 across the board.
Comes with the complete engine longblock, transmission, motor mounts, shift linkage, axles(has torn cv boot) wiring harness, ecu. $2350
Radiator Fan $25
Condenser Fan $25
Air conditioning Condenser $35
Power Steering pump $40
Power Steering Rack $100
Clutch Master Cylinder and Reservoir $65
ABS Brain and Distribution cylinder $50
A/C Lines (From condesnsor to evaporator and back) - $55
Battery Tray and Holddown - $20
Clutch Line (From master cylinder to slave cylinder) - $20
ABS Proportioning Valve - $15
Cruise Control unit and cable - $40
Front Wiper Arms - $20
Front Subframe - $80
Pedal Assembly(Gas, Brake, Clutch) - $60
Windshild wiper motor $35
Cowl $25
Fuse box(underhood) $20
Gas Tank(with sending unit and fuel pump)and straps $85
Gas tank filler neck and cap $25
Sunroof motor and glass(complete unit) $100
Headliner(small hole) $25
If you dont see something small listed then ask i might have it, thanks for looking!
If you need pictures or have questions email me at napster56754@aol.com and include in the subject your from hondatech about the integra.
I will respond to pm's however i do not know how to send pictures through them.
Please bump if you look!
Old Oct 26, 2010 | 07:56 AM
B16Civic93's Avatar
Default Re: 1999 Acura Integra GSR Part-out (Tan Int. Cypress Green Ext.)
buy em!
Old Oct 27, 2010 | 12:35 PM
B16Civic93's Avatar
bump it
Old Oct 29, 2010 | 03:55 PM
B16Civic93's Avatar
parts!!
Old Oct 31, 2010 | 03:33 PM
B16Civic93's Avatar
someone has to need this stuff!
Old Nov 3, 2010 | 04:08 AM
Sh!nny's Avatar
got the pass front fender?
Old Nov 3, 2010 | 12:22 PM
B16Civic93's Avatar
no sorry most of the body parts are gone.. i've got a passenger side door. Need one of those? I'd like to sell it to you lol
Old Nov 4, 2010 | 02:33 PM
B16Civic93's Avatar
buy my parts!
Old Nov 5, 2010 | 07:55 AM
B16Civic93's Avatar
up
Old Nov 6, 2010 | 04:00 PM
B16Civic93's Avatar
buy my parts!
Old Nov 8, 2010 | 07:44 AM
B16Civic93's Avatar
NOON!
Old Nov 8, 2010 | 07:59 AM
Sh!nny's Avatar
whats the best u can do for the pass door...
Old Nov 8, 2010 | 08:27 PM
JDM_DAKiD's Avatar
do you have the exhaust/b pipe?
Old Nov 9, 2010 | 03:18 PM
B16Civic93's Avatar
pm'd both
Old Nov 10, 2010 | 08:48 AM
claysno's Avatar
how many miles on the complete swap where r u located in md and if i came and picked it up would u take 2200 cash
Old Nov 10, 2010 | 09:08 PM
B16Civic93's Avatar
pm'd
Old Nov 12, 2010 | 02:25 PM
B16Civic93's Avatar
flakey buyers...
Old Nov 13, 2010 | 08:45 AM
Sleeperzzz95's Avatar
Emailed ya!
Old Nov 13, 2010 | 08:53 AM
B16Civic93's Avatar
replied
Old Nov 13, 2010 | 08:57 AM
Cool Guy.. Even tho I Misread the Description lol
Old Nov 14, 2010 | 08:10 AM
B16Civic93's Avatar
make offers!
Old Nov 16, 2010 | 09:16 AM
B16Civic93's Avatar
someone buy my parts!!!
Old Nov 17, 2010 | 10:22 AM
B16Civic93's Avatar
parts!
Old Nov 18, 2010 | 08:47 AM
B16Civic93's Avatar
parts!
Old Nov 19, 2010 | 07:29 AM
B16Civic93's Avatar
top
